Try the Putco bar/harness? Works great on my 2019 HC
Ryan B.
Thank you sir. I bought the harness you recommended and now it all indeed works! You saved me a lot of grief. Now I’m happy! Thanks a million!
I purchased one of the newer bars that has 4 rows of LEDs. One row is dedicated white for reverse and it’s very bright.
I hard wired into my trailer 7 pin connector under the bumper. Just removed about 1/4” of the insulation away from the wires then soldered in the new wires. Didn’t cut the originals and taped up all the joints to keep it from shorting put. Works great.
Putco 60" is available thru GM accessories.
https://accessories.chevrolet.com/product/60-inch-blade-led-tailgate-light-bar-by-putco-associated-accessories-19418352?year=2020&make=Chevrolet&model=Silverado 1500&modelId=491&body=Crew Cab Pickup&bodyId=22&wheel=Short Box&wheelId=651&trim=High Country&trimId=523&drive=4WD&driveId=8&engine=6.2L V8 GAS&engineId=5920&bodyNumDoors=5&categoryId=197502
Crew Cab Pickup : Short Box : High Country : 4WD : 6.2L V8 GAS
640X640search.svg
60-Inch Blade LED Tailgate Light Bar by Putco - Associated Accessories
Part No. : 19418352
MSRP $299.00*
You could earn up to 1,794 points1 from My Chevrolet Rewards by enrolling.
  • Communicates your braking, reversing and turning intentions to other drivers
  • High-power LEDs provide brilliant and defining light output
  • Comes with all installation hardware and is easy to install
  • Includes wiring harness
  • Enhances the appearance of your vehicle
640X640search.svg
Part No. : 19418352
MSRP $299.00*
Good to know!  I can use some rewards points to knock the price down.
Only question I have is which harness are they including. Is it the quick connect harness (529004) which I have read many people have had good luck with?  Would I still need to purchase that separately for $60?  If so, that would make it much less attractive.
I might shoot them an email to find out.
I have the Redline light bar with the Putco harness. I also purchased the Redline module originally, but it didn’t work with their recommended setup. Neither did their Curt harness. The reason I picked Redline light bar was the sequential amber turn signal and obviously the lower price. Everything from Amazon Putco 529005 Blade Quick Connect. 19 Silverado High Country 6.2 L V8 gas.
Edited by George Zaheu
George,
Is your truck equipped with the Tow Package/Safety Features package (Blind Spot detection, park assist, etc)? I've got a 2020 GMC Sierra with the Safety Features Package and wanted to know if the Putco harness allows the Redline light bar to work without any towing warnings or prevention of the Safety Features from working.
Thanks for the info!
Daryl
Yes sir! It works just as it should. Putco harness plugs in between your connectors for each side driver and passenger and the backup wire from your Redline has a socket dedicated on the harness as well. The biggest inconvenience I had was to take the gate off the truck. You’ll have to remove the big socket underneath for the power lift gate and camera, sensors etc. Good luck. Ask for more info if needed
I don’t have the tow package. I’m looking to hardwire an led strip my wife bought me. It has the 4 pin connector but I don’t want to connect that because it’ll look cheesy. Is it just color matching? Any diagrams? I also want to hook up the reverse lights. It has the extra wire for that. Should I just tap that directly to the reverse lights or is there a wire that I could tap in the back of my harness? Thanks
Easiest way to go is to buy this Putco harness we’re talking about from Amazon and you’ll be done in no time. Honest opinion. It takes care of all your concerns click and done.
Just purchased putcos harness. Found it for $51.00. Curious why you took your tailgate off? Was it easier to install the light bar that way?
The reason is, it helps with the alignment of the light bar. Up, down and left, right. It would be too awkward to try to reach under the gate. That’s all.
George,
Was installing the Putco harness difficult? I"m guessing(hoping) the harness comes with installation instructions? Any of the connectors difficult to get to? Any install information/tips greatly appreciated!
The harness does come with two pages of very clear instructions. You should have no trouble at all following them. As I said, it would make your life easier to take the gate off, but if you struggle a little bit I guess it could be done with the gate on. Make sure you clean the surface really good for proper adherence. Good luck. I’m here to help any which way I can.
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,417 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
