2 more observations, it appears that there is a hex type of crimp made, which is common for coax. I also see it appears the ferrule appears to be threaded as it has a grip type exterior to assist in tightening without slipping on the connector. But why is the inside of the boot a small round metal, what was the mating part, was that lost on the cable destruction?
Chuck
It looks like that is coaxial cable, not triaxial.
They could send power and signal on the same cable. Just like they do with Direct TV satellite dishes. It makes aftermarket cameras more difficult...
If you know any Ham Radio operators one of them could probably crimp or solder a different connector (maybe a SMA)?
You would need to do this on both the truck end and camera end.
Search for RG58 SMA connector on You Tube there is a video that shows how to install a crimp on connector if you have the Hex crimper.
If you were in Phoenix I could install the connectors in a few minutes, there is bound to be someone that could do it in your area.
When I have time I will see how much extra coax there is under the truck. If there’s a little slack it would be easy to cut the coax and put connectors on both ends. I could add a set of camera jacks in the bed for a fifth wheel or gooseneck.
I currently have a furrion wireless camera on the back of my fifth wheel with extra monitor.  Would love to be able to use the gmc screen so I wouldn't have to have an extra screen sitting there.  However the GMC camera is a "wired" camera.  How do you run the wiring from the back of your camping trailer to the plug without it looking cheesy?
i found a 'hole' at the front of my horse trailer where the manufacturer had run the wires for the brakes/lights.  There is a track all the way to the back of the trailer so i used it for my camera cable also...at the front, it drops directly down around the gooseneck hitch, so i cable clamped it backwards to just over the trucks connection.  CAUTION! i did not allow for a sharp turn of the gooseneck and the first time i did that the camera cables ripped out of the truck connection and i will have to get new connectors which have been difficult to find!!
Could you also cable clamp the wiring underneath your trailer to the rear? i used self tapping metal screws and it was fairly easy...
I agree it looks like 'mini' coax and seems to have the same type of termination, but when i was researching the type of camera/connectors, i found a site that said the cameras were using triaxial.. i will look back to see if i can find that again.
I looked under my truck today.
The camera cable is RG-58, 50 ohm coax.
If I had damage to the connector I would just replace it with a compression F connector. Direct TV uses these outdoors in all US climate zones.
Put in a splitter and you can have jacks for your 5th wheel and on your bumper. I would cut off the camera plug and replace wi a F connector as well.
Not sure if this has been said but dealer ran my vin and this P/N 84876818 is what came up replaces 84580657.
WRONG. RG-58 is a standard in radio and GPS. we commonly use it in aircraft. Directv does NOT use this. They use RG-6 and sometimes RG-59 if the installer is lazy. In addition you cannot use a splitter in this application. If you listen to this guy your camera will be damaged at the least.
I didn’t say Direct TV uses RG59 or RG58. I said they use F-connectors...
They use RG6 because it is lower loss at the microwave frequencies they are using than RG59.
RG58 is 50 ohm RG59 is 75 ohm. At the signal levels used here they would be interchangeable but I didn’t suggest that.
Putting a splitter won’t damage your camera. Even if you were so incompetent that you inverted the signal and ground it wouldn’t hurt the camera. The voltage that powers the camera is supplied by the truck. I would put a 50 ohm terminating cap resistor on the unused terminal.
It wouldn’t be a good idea to ground the unused terminal.
I will order a camera.
    sportfish17
    sportfish17
  • Who's Online   5 Members, 2 Anonymous, 2,009 Guests (See full list)
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
