  • Replies 44
Top Posters In This Topic
Wow.  P20EE.... the same code that troubled many of us 2017-2018 model year owners with the duramax.  Took a year to get a fix.  In the meantime, my CEL came on probably 20 times.  Nice to see it comes back up in the new model.
I have a 2020 2500 Duramax a Silverado. Check engine light came on at 500 miles had Chevy reset and Regen comes on every 150 miles been in 9 times field engineer sent fix to government for approval
16 hours ago, Girthyhawg said:
2020 HD light just came in tonight 1900mi... will update after dealer visit.
Just left dealer...
p20EE bulletin #pip5664a
reset nox1 sensor and performed box deduct any test.
asked dealer if it happens again, I hear some ppl have issue every 150mi... he said it won’t, so I’m wondering if that bulletin was the software fix?
SES light on 4 times since order. 2500 DMax Denali. Going back in on 9/30. The light comes on after a prolonged highway ride then disappears. P20EE, emissions. Correct, no remote start when it’s on and it’s pissing me off. Picked up with the 35 mile run-in and now have 1600 miles.
Check engine light came on yesterday at 6091 miles.  Going to take it in tomorrow to see what the deal is.  Was towing 200 miles from home so that was fun driving home hoping nothing major was wrong.
Edit: OnStar was finally able to get the diagnostics to work and it's the P20ee code.
Edited by Irish80
Had the check engine light come on, on my 2020 z71 dmax and also remote start didn't work as well. I have 800 miles on it. I took it into the dealer and i will hear back and update as well. The remote start doesnt work anytime the check engine light comes on, that is a feature as another user said.
I was on a 1600 mile one way trip today and got the same check engine light...I was at 1650 on the odometer when it came on...OnStar ran diagnostics and told me to service at my convenience...it’s 20° where I’m at and would like to remote start...won’t be home until the 16th...I did get 20.5mpg over the 1630 miles...way better than my 19 power stroke
Picked mine up from the dealer last night P20EE emissions code 2nd visit.  The first time they just reset it, this time loaded new software for the NOx sensor so I will cross my fingers and wait.  BTW the code only comes in on long highway trips. It usually resets (SES light) on its own a few days after city driving.  Which is nice because you get your remote start back.
p20ee came on today on trip - stopped at dealer and they put new fix in - were also doing their trucks on lot
'Remote start disabled' if there is an active CEL was a 'feature' on earlier generations as well.
Dealer not filling the def tank at delivery has also been an ongoing problem, for as long as we've had def.
For many, this means and early and unexpected warning to add def -- and an assumption that it was because of high consumption rate.
Just like fuel tank level, the def tank is NOT filled at the factory.  For trucks purchased after sitting on a lot this is probably a good thing.
not checking DEF level is like not checking fuel gauge when picking up new at dealer. Its your fault. CEL has stayed off since fix at dealer last thursday. P20EE fix finally has worked.
    Bulldogger
    Bulldogger
  • Who's Online   5 Members, 1 Anonymous, 836 Guests (See full list)
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way to big should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crosing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
    • And overpriced. I was in the Oshawa Truck Plant when they were being built. Very few. I could count on one hand how many I've seen since
