20 hours ago, BB&Chiveon said:
not checking DEF level is like not checking fuel gauge when picking up new at dealer. Its your fault. CEL has stayed off since fix at dealer last thursday. P20EE fix finally has worked.
Might be true on 2020's, if the 'gauge' is accurate -- I don't have a '20, but it sounds like there are issues with it.
2011 there was no def gauge at all -- just the miles remaining warnings.
2012 - 2019 have a def level indicator.  Won't tell you if it's full -- only gives a %  indication if it thinks their is less than 30%.  Above 30 it just says 'OK'.  Which of course is useless for 'checking to see if full'.
Ya, I know, it's a 2020 thread.
Edited by redwngr
  • Replies 44
Top Posters In This Topic
What was the fix for this problem. I’ve been to dealer 3 times and they said GM told them the fuel pump module is bad. I doubt this is the problem
On 1/20/2020 at 9:23 PM, Fl cowboy said:
I have a 2018 idling around today got a p026d code can anyone give me advice
Truck thinks it has a faulty DEF sensor.
I'd guess they will install a new one.
Let us know.
I'd still take it in and have the code scanned and documented.
I have a 2020 Sierra with 400 miles and the check engine light on.  I see others have had this issue.  Has it been resolved for most, or something I need to get used to.
Not something to get used to.
At 400 miles, get it to a dealer and make use of the warranty you paid for.
There are 100's (or 1000's) of things that could be the cause for the light.
Typically, much easier to find with some service training and with use of a diagnostic computer to help track it down.
You can hit the OnStar button, and they will give you the error codes / DTC's if you are curious...
Check engine came on my truck today at 15k. I went to auto-zone to get check and it wasn’t showing anything (maybe truck is too new for their device) and thn I called OnStar (P20EE) showed.
I’ll be going to dealer next week.
Edited by TrailDemon
I got the P20EE code at 800 miles after pulling a trailer for an extended period of time. I reset the light and it has not come back on in over 7000 miles.
Sent from my SM-G981U using Tapatalk
I hate to see that light so I reset as well. Already drove 100+ miles and still clear dash
  • 6 months later...
5,777 miles.
2020 Chevy Silverado 2500.
When put in drive, lags down, truck shuts down. Rear end locked up when trying to put on flatbed tow truck. Same email as others : engine and transmission issue detected.
being towed to the dealership as I type this.
12/28/20
17:00
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.   [img]https://live.staticflickr.com/65535/55462229387_5c9bbe5416_b.jpg[/img]   NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.   [img]https://live.staticflickr.com/65535/55463207451_16a229e2f8_b.jpg[/img]   I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:   [img]https://live.staticflickr.com/65535/55463598785_88e6de0164_b.jpg[/img]   And the issue which occurred because the front rail clamp was too far forward:   [img]https://live.staticflickr.com/65535/55463206526_7d19819403_b.jpg[/img]   Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.   [img]https://live.staticflickr.com/65535/55463377309_a18f23d493_b.jpg[/img]   The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
    • Same here, first I bought a few filters to get me going right after I bought my truck to do some short distance initial oil changes, then realized I could buy a case lot for less as they drop the price if filters or trans oil etc is bought by the un opened case lot as well as the discount for buying the vehicle there. So I have filters for a while but its good to know going forward, knowing to expect it to be a different part number and looking filter at the dealer and not be confused over it and think they are handing me the wrong part.
    • Saw Inglewood was in the National New last night for hail. Allot of hail. front end loader level hail. 😱
