On my 2017 Sierra SLE 5.3L it would change from V8 to V4 depending on how many cylinders were active.
In my 2019 Sierra SLT 5.3L there is not a display saying how many cylinders are active (2-8). Maybe I do not have an option turned on. What are your thoughts?
It is all done behind the scenes. Nothing to activate or deactivate. Sit back, enjoy the ride.
I liked knowing how many cylinders were in use. My 2017 displayed it. Just out of interest. It would of been nice for them to keep that status on the display to see what was happening behind the scenes.
Yeah, just not possible though. The patterns are too wacky and alternate so quickly. The consumer would have no idea what to do with the info.
  • Thanks 1
Did anyone really need the display to tell them when their AFM 5.3Ls went to V4? I sure didn't.
As Marky Marky said... "feel the vibration!" ?
  • Like 3
  • Haha 1
Did I need to know on the 2017? No. I found it interesting. Do I need the transmission temperature? No I find it interesting.  Do I need to know what percent climb or decent or left or right angles are? Not really...  all of these are interesting and could be useful. But I don’t need them. I do enjoy seeing the details.
  • Like 4
  • Thanks 1
I can tell the change in the exhaust note and a slight change in rpm.  M9 takes all that away.
Please for your sake do not look at the brake wear screen [emoji1787]
Ryan B.
  • Haha 3
It would be cool if one of the displays would show how many cylinders are firing and maybe even what gear you are in. If you barely have your foot on the gas it drops cylinders a lot. Just put on a aftermarket exhaust you still wont have a visual display but you will audibly recognize it.
I can see it now. “Hey honey. My truck needs a new exhaust so I can verify the number of cylinders being used.” I think she would hit me with a frying pan. LOL
Edited by Phoneline99
  • Haha 3
There’s only one pattern I can easily pick out with the performance exhaust. It’s on my way home, around 30 mph, flat ground. It sounds cool though. It’s rhythmic. No idea how it sounds outside the truck, but probably weird.
  • Thanks 1
In one of the videos TFL did they rode around with an engineer that had a device plugged into the obd that showed how many cylinders were firing. If i remember correctly it was constantly changing, it would be more of a distraction.
Sent from my ONEPLUS A6013 using Tapatalk
  • Thanks 1
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
