Anyone know if this will fit on 2019 GMC Sierra 2500 HD, also couldn’t find that part.
Don't know if it will fit.  But if you find out it will, I just took mine off and I'm happy to sell it.
Still have it?  Have any pictures?  What are you asking for it?
sent pm
When folded does it fold down or forward? I have an Undercover UltraFlex hard cover and trying to determine if it will fit.
It folds straight down. Step dad just got a new Sierra SLT and loves it. Calls it his old mans step handle!!  LOL. I found it very useful to use. I am thinking of adding this to my High Country
  • 10 months later...
On 8/21/2019 at 4:24 PM, Snuff said:
Thought I would share a picture of the GMC Tailgate Handle on my RST. I ordered it from the GMC Dealer and installed it in 5 minutes. It works great and very useful to this old man.
Yes, that would be a great option, but my bedrails are using some of the mounting holes that this GMC product appears to use, so I can't use it unfortunately.
I added this to my Trail Boss.  I also have a Retrax bed cover.  It doesn't interfere with the bed cover at all.
21 Denali 1500
Retrax mx bedcover (they poly one...)
Handle does not interfere with the rails.
I still use the the bumper step with stake pocket for a handle more often than opening the multipro inner and folding down the handle.
I ordered one of these and it did not come with the hardware to mount it. Can anyone confirm theirs included the hardware?
Ordered my Tailgate Handle a week ago from my dealer and I can confirm it doesn't come with the hardware.
I will post the hardware part numbers as soon as I receive my order and confirm the three hardware part numbers.
BTW the correct Tailgate Handle part number is now 84726114.
I'll also will post some pictures of all the parts before it's installed as it's a simple install.
Looking forward to try this handle out as I'm having trouble accessing the truck's bed area.
6 hours ago, Rubyralph said:
I ordered my Tailgate Handle a week ago from my dealer and I can confirm it doesn't come with the hardware.
I will post the GM hardware part numbers as soon as I receive my order and confirm the three hardware part numbers.
I'm looking forward to try this handle out as I'm having trouble accessing the truck's bed area.
Well I no longer than sent this out and I got a call that my parts were in so here yo go:
Parts required for my truck's steel box with the one piece tailgate:
Hardware for factory DIY Tailgate Handle install:
Backup plate bracket 84338560.
8mm-1.25 nuts for backup plate 11546459 (2 required)
8mm-1.25x 24.5 long bolt for truck box 11602770 (I re-tapped the box threads as my factory spray-in liner required it)
Works great for me, hope this helps!
Edited by Rubyralph
spelling
Mine came stock and my BakFlip MX4 folding cover fits with no interference.
Installed picture, glad I found this easy mod to help me get into my truck's bed!
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 384 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
