My truck has had an odd hesitation that started a few weeks ago. To me it feels like a bad spark plug, wire or COP. I have tried to test and narrow it down, but looking for some thoughts.
Truck has 55k on it. Mods are K&N intake/filter, Gibson dual exhaust, 2017 Duramas hood (full ram air hood) and a Diablo tune. No other mods besides tires.
The hesitation only happens after the truck is warmed up. When it is cold, it doesn't do it. It is a slight hesitation/stuttering. Doesn't matter if it is going up a hill or flat.
I have changed the plugs (replaced with stock) and changed the wires (again with stock). Really don't want to waste $400 on a set of COPs unless I need to. Cleaned the K&N. All this made it a little better, but it still happens. I reverted back to the stock tune, it didn't change anything. Tried running it in trailer-mode, still happens.
Thoughts?
My truck does a hesitation it feels like if I'm not on it , and just rolling through want to say 2nd to 3rd if I give it more gas seems to go away.  Have basically the same mods you have minus the tune but, kind or feels like when you shift into to high of a gear n truck lugs a bit .
 I have a 2016 2500 6.0 , dont know if we are experiencing the same thing but going to be bringing it in soon
Sounds like the same thing. It is definitely with lite throttle and between 2nd/3rd gear. And it goes away if I give it more gas.
Please let me know what you find out. I will do the same if I find a fix.
Thanks!
Thanks!
I surely will keep you posted as soon as I find anything out
Torque converter?  We've replaced some on 6.0/6L90 trucks for shudders and hesitations in the 2-3 gear, 20-40mph range.  Between 2015-2017 model years, between 13-67k miles, some with tow haul on or off.  Some had P0741 code, converter clutch stuck off.
Quote
#19-NA-153: Malfunction Indicator Lamp (MIL) Illuminated - DTC P0741 Set - (Aug 7, 2019)
Some customers may comment that the MIL is Illuminated.
Some technicians may find DTC P0741 (Torque Converter Clutch (TCC) System Stuck Off) set as an active or history code.
This condition may be caused by a damaged clutch friction material in the torque converter in vehicles with mileage above 30,000.
Perform a line pressure check.
    • If the line pressure is low, check the trans pump for damage and refer to the latest version of PI1447.
  1. Connect GDS to the vehicle for a road test.
  2. Select TCM and navigate to the TCC dynamic test screen.
  3. Drive the vehicle at approximately 10 mph and command the TCC on and off several times. Note if the TCC engages;
    • Should feel TCC engagement and see tachometer drop.
    • TCC slip speed will drop to near zero.
  • If TCC does not engage, refer to SI for P0741 to test for circuit/electrical problem and/or sticking TCC apply valve.
  • If the TCC does engage, refer to the Service Procedure below.
Edited by newdude
I’d run fuel injector cleaner. Had same thing happen to me with a 16 Yukon, dealer wanted to charge me a few hundred so took it home and started using Lucas Fuel treatment and after a few tanks it just disappeared. I’ve been using it in my fuel in every vehicle on every other fill up.
Thanks. Will try some injector cleaner. Going to the dealership today anyways, so will ask them about the Torque converter.
I am at the dealership now and they are looking into the problem. The service manager told me there are known issues with the 15/16 transmission and torque converter. They have three 2500s in the shop right now for tranny/torque converter issues.
dealership could not replicate the issue with the torque converter. They turned it on/off and tried to force it, but it didn't fail. They now are looking at the A/C, as that seems to have a direct correlation with the stumbling/hesitation.
I have noticed the same thing in a few similar trucks I’ve driven.   I wonder if the variable valve timing leans to the economy side and that is the hesitation that is felt.  Def sub’d to see what the outcome is.
Edited by DaBomb6988
First I have really heard of this. Seems once in a while these trucks need torque converters but it doesnt seem like a common issue at all. Sure they are not talking about 1500?
I couldn't see the all the trucks, but he did point out one that was on a lift which was a 2500.
The dealership didn't fix anything. They basically told me if it gets worse to come back and see them.
I still feel like it is a transmission issue, as the issues didn't start until after I had the tranny flushed at the dealership. Prior to that, it was rock solid. I just wish it would throw a CEL and I would have something to go off of. Right now, no CEL and nothing points to an issue.
  • 4 weeks later...
Well back to the dealership it goes... this time we are going to try a tranny fluid/filter change and not a flush. It seems to be getting worse with no real explanation from anyone. No CEL. I have taken people for rides and they keep asking me what is wrong with my truck. I am embarrassed to drive the truck with friends and family now, it is that bad. Have resorted to driving my wife's F*rd, if I need to take anyone with me.
  • 1 year later...
Mine just went in for this a week ago....said they ate gonna rebuild my trans..
Sent from my SM-N950U using Tapatalk
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
