On 10/2/2019 at 8:53 PM, dieselfan1 said:
Actually I don't buy into the marketing hype. Harvick is just another schmuck to me.
I've used Mobil 1 since Harvick was in first grade.
I’ve used Mobil1 for years as well until one day I looked into the Full Synthetic versus 100% labeling and was SHOCKED at just how misleading the Full Synthetic was, no where near the protection of a true 100% synthetic base stock oil and yet Mobil1 was more expensive per quart than Amsoil.
Research and you’ll find that Amsoil Signature Series is at least 4X better than Mobil1, completely beating Mobil1’s Annual Protection.
Oil companies in this country, manipulating everything, whether its politics or transportation, cost of traveling, tires, food etc etc.
Amsoil is 100% Synthetic from base stock oil throughout the 100% Synthetic Additives, Mobil1 is made from much cheaper (Dino Oil) mixed with 100% Synthetic Additives.
Amsoil clearly is the BIG WINNER here.
So at 4X more Protection and cheaper to buy, Amsoil has made a lifer of me.
Sent from Above
Edited by txab
Except nobody in their right mind buys it in 1 qt bottles for doing oil changes.  You buy 5 qts for $30cdn (less in USD) for Mobil1.  Amsoil only sells in their 1qt things, and it's more than double the cost.
Actually, AMSOIL has gallons, 2.5 gallons, 30 gallon drums, 55 gallon drums, 275 gallon tots available on some of their products.   Like for the Duramax crowd that uses 10qts.  You can get a case, (2ea of 2.5 gallon jugs) and that will do 2 oil changes and the cost per qt is less buying it that way.    Also like in our 2016 Suburban which is 8qts or 2 gallons.  I just pour in 2 gallons of the ASM 0w-20 no extra left over from a 5qt container.  Easy peazy!
I know several agricultural business that own 3/4 million $ equipment (Ponsse Scorpions with MB diesels) and AMSOIL Signature Series 5W-30 is all they use + AMSOIL Off-road grease. As one of them told me, before the AMSOIL grease they were constantly replacing bearing and suffered a lot of down time.  The min oil change interval per manf. is 600 hrs (min) on 8 gallons.
I don’t buy based on how cheap it is, I buy it basing on Protection and if it’s in quarts then so be it. You’re buying oil that is half the price because you’re buying the cheaper quality, less protective oil. Amsoil is actually cheaper than the highest quality Mobil1 Annual Protection which is offered with stringer synthetic cleaners. Moving on, stick to what makes you happy, Amsoil isn’t for the budget buying individual that’s just looking to meet specs, it’s for people wanting the most available protection between oil changes giving less wear and tear on their engines throughout the duration.
Sent from Above
You’re correct, protect your investment and If you want to just use what’s recommended then that’s everyone’s option but if keeping it going with less wear and tear from the highest available protection then Amsoil is a no brainer, especially high dollar machinery.
Sent from Above
Let’s focus here, started this thread showing proof that Amsoil is the best and why I recommend it so much. I’m not at all associated with Amsoil, it’s made a huge difference for me and the way my vehicle runs. So, this being said, there’s no need to bring up low price oil because this thread is about the best oil and what makes it the best.
Whether you’re buying oil that just meets specs or because you’re looking to get more bang for your buck, Amsoil Signature Series completely blows away the competition.
Ever wonder why are big oil companies using regular base oil with 100% synthetic additives (which is what Full Synthetic is) when you can have real 100% synthetic base oil with 100% synthetic additives.....You get what you pay for, superior protection between oil changes!
Sent from Above
Here's VIRGIN Mobil 1 0W20 Annual Protection. Looks about the same additive wise as any $3 CONVENTIONAL. Actually…..it is below universal averages. There's some ZZDP numbers that will take your breath away. Crisco?
Edited by txab
Folks, as even the video states, there are those that you, no one can reason with. Immediately jumping into a discussion explaining that Amsoil saves you money on extended oil changes. Most people that care about their motors will do oil changes at 5K miles, Amsoil is 25k guaranteed oil for normal driving and 15k for heavy duty use. So, immediately you can see the the savings doing a 10k mile oil change. What takes the typical driver a minimum of 4 quarts per 1 of Amsoil and that’s 4 quarts of Mobil1’s finest (Annual Protection) not the basic Mobil1 Full Synthetic which competes with Crisco.
Amsoil offers minimum 4X more protection of Mobil1’s leading oil “Annual Protection”, so if you cannot immediately see the benefits of choosing not only the highest protection rated motor oil currently available then you REALLY shouldn’t speak out because this isn’t about comparing Mobil1’s lower priced full synthetic it’s about highest rated against Amsoil.
Sent from Above
Edited by txab
Remember, this discussion is about the protection given by Amsoil when compared to leading Full Synthetics, costing you minimum 4 oil changes to every 1 of Amsoil which in return saves you lots of money.
Sent from Above
Cheap isn’t The Best
I'll use my Quaker State Ultimate Durability "full synthetic" I bought for $3 a guart after rebate and I'll be fine. Change it 4-5k (twice a year), truck will last as long as I need it.
9 hours ago, Grumpy Bear said:
Guys beg for PROOF and when they get it ignore it. Read the comments section of this report. Pay attention to them.
Zinc, Phosphorus and TBN.
There is nothing there that even remotely suggest this is a 20,000 oil.
Mobil/Exxon is a marking company.
Here’s the filter I highly recommend Wix XP, it’s a fully synthetic material that captures small as 20-21 microns, complimenting Amsoil Signature Series.
Double Check to make sure it’s for your year and engine.
Sent from Above
