Lookin for replacement shocks
I have a 2015 ls Silverado 1500 5.3l. The rear shocks are leaking so I’m going to replace them. Looking to see what kind of shock I should get. The tuck is actually classified as a work truck though we use it as the family vehicle. It rides pretty hard as you would expect. I rarely if at all tow anything and hardly haul anything of significant weight.  Any input on which shock I should get why would be greatly appreciated.
If you didn't have any issues with the factory AC delco shocks (other than age/wear causing the leak), I'd honestly go straight back to using those again.
I've had good luck with the higher end shocks from napa, I just forget the brand off hand. No rancho shocks though.
yes those OEM shocks are very good, aftermarket is all made in CHina with a US brand name... but i could be wrong. those bilsteins have a great reputation.
5 minutes ago, DeePa said:
Rears are easy. Fronts you’ll need to have a shop swap over the springs or do the install.
Alignment afterwards never hurts
Even with spring compressors?
9 minutes ago, DeePa said:
High end ones / wall mounted ones meant for truck springs?  Sure.
Rent a compressor or from auto zone?  No.
Thanks for advice.  I will probably just take them to a shop like you mentioned then. Really appreciate your help DeePa. Thank you
Bilsteins are overrated.  If I wasn't using them to level my truck I'd have swapped them out for something that doesn't ride so stiff.
I replaced the Rancho shocks on my 2014 Z71 with Bilsteins big costly mistake. The Bilsteins really screwed up the ride. Not a thing wrong with the Ranchos I removed. If I ever do need to replace the shocks on my 2019 will be staying with the factory oems. Did get some cool stickers with the Bilsteins.
You think your truck rides rough now, you wait till you get those 5100s on there.
    Selfman
    Selfman
  • Who's Online   6 Members, 0 Anonymous, 501 Guests (See full list)
