Fan Stays Running - Feature or Malfunction?
My cooling fan(s) occasionally stay running after the truck is turned off. I've noticed this twice now and only happens when shutting the truck off after some spirited driving. Both times the temp gauge has been above 210 (slightly) at the time of shutdown. I waited about 5 min and the fans were still on so restarted, let run for approx 1 min and shut down. The fans turned off at that point.
Is this a feature to cool the engine after it is shut down, or do I have a relay or programming issue somewhere?
I have never had my cooling fan run after a turn off of the vehicle.  I have noticed it come on directly after I start the vehicle if its warm then it goes off after a short time.  This is on my 5.3.  6.2's might have other metrics as to when the fan runs?
31 minutes ago, sk said:
It is a GM feature called "afterblow" (no I didn't make that up).  It is meant to dry the evaporator core so you don't get that moldy smell from your A/C.  On some years it came already enabled but on others the Techs had to enable it later after people started to complain about it.
https://www.underhoodservice.com/gm-eliminating-air-conditioning-odor/
He is saying the engine cooling fan stays running, not the HVAC fan.
OP,  it's a Feature, normal, been that way on many vehicles across the board for years now.  If it bothers you that bad, shut off your a/c during the last 5 minutes of your drive and sweat it out.
He's talking about the engine cooling fan under the hood.
NOT the HVAC blower
But I would assume its normal. Probably shuts off withing a couple minutes. Lots of cars do that in the hot months.
I've noticed the ENGINE FAN remaining on sometimes on a hot day in every electric fanned vehicle I've ever had.  You're fine.
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
