I have kept it in the center console attached to a magnet, but was wondering if anyone else has come up with a better concealment idea.
I just got used to keeping it on me holstered. If I'm going where I know I cannot carry (like work) I usually leave it home, otherwise lock it in a secured under-seat vault, but if I'm carrying it stays on my person even in the vehicle.
Dont keep a firearm in your truck...it goes with you or thieves get a bonus with a free truck
  • Like 4
center console but only when i'm with it. there is a company that makes a holster designed for under your seat. basically you can reach between your legs to pull it out, thought that was a neat idea but not enough to spend the cash.
Any idea what the company's name was?
Sent from my Pixel 2 XL using Tapatalk
I have mine just in a cheap Uncle Mike's holster.  For a smaller gun (Ruger LC9) I can clip in right on that little cubby towards the front of the console.  The lid still shuts and everything.
1 hour ago, ChinkySuperman said:
I want to keep it underneath the seat.  I just ordered some big neodymium magnets, what i'm plan on doing is use my 3d printer to print a holder that fit my specific handgun in a specific location.
i'd be leery of magnets. you can probably rig up an old holster though.
I always keep my pistol on my person unless I have to go into a prohibited area.  Then I lock it in a tethered lockbox under the rear seat.  You are much more likely to need access to your pistol outside of your truck, such as when refueling.  Better to always have it on you.
  • Like 5
