I changed out my console lid to one with storage but there is no organizer available for the jump seat type console so I made one on my printer.
I have the .stl files for these if anyone has access to a 3Dprinter.
  • Like 12
I was tossing around the idea of designing and printing an organizer for my jump seat console but if you already have an stl file you’re willing to share I would like to get a copy.
14 hours ago, matthewthughes said:
We have one at work can you send me the files?
Sent
Please send me this file as well.
I would suggest posting it to thingiverse and then posting a link here. The more people posting these designs, the better it is for all of us T1 owners.
Nice job sir.
This is outstanding! I love the way 3D printing is revolutionizing the way we solve problems.
My son is in the process of printing one up for me right now, it will be a two piece (due to the size of his print bed) but it will sit in the slot's on the top part of the console.
Edited by TweetybyrdRT
spelling correction
Anyone willing to make me one of these? I will pay of course but I don't have anyone that I know that has a printer and this looks awesome.
    • I had an alternator fail that was shorted internally in such a direct fashion in addition to the larger gauge cables that it appeared like a VERY dead battery. Granted I think the car did power up, it definitely wouldn't start.   Rodent damage to wiring?
    • ... I don't think he could.
    • Using experience to justify bad advice is lazy and typical of someone incapable of articulating why their advice is prudent.    This immediately sets off the BS alert and the advice that followed certainly qualified.   Asking an idiot for help getting out of dumb situations because he is an expert... at getting himself into dumb situations.   Unless I've been living in an alternate universe - the first thing everyone does when getting into a sticky situation is shift to a higher gear 🤨.   Of course not, the torque multiplication, mechanical advantage and finer control typically afforded by the lower gear is far better suited for this scenario.   There ARE scenarios where a higher gear MIGHT be appropriate determined more by the drivers ability to control EXCESSIVE wheel spin versus applying torque to the ground.
    • I'm not sure I agree with "extreme" low speed, high torque sentiment here with regards to the prescribed use of low range. How about...whenever it's needed?   A 2.72:1 transfer case and whatever differential gears these Silverados have (3.42's, maybe?) aren't producing "extremely" low crawl speeds. Or insanely high torque multiplication. Even with the 1st gear in these newer transmissions. But it does provide mechanical advantage and potentially better control at slower speeds. And with extra weight or towing, I think it adds mechanical sympathy for the truck as well.   Plus, traction control and the other assists generally turn off when you shift into low range. Those aren't needed here, they'll work against you if you need wheel spin. In high range you'll need to figure out how to turn off the various modes those assists provide. Depending on the vehicle, those things don't all automatically turn off or turn completely off.   While I agree that a farmer might have some great practical experience, a recommendation to "always" using one gear isn't very informed advice. If the farmer had said WHY and could explain the physics behind his prescriptive "always" I'd definitely listen. The way he's described here makes it sounds like he could either be uninformed or is telling everyone what worked for him, not necessarily that there could be a more advantageous way about things.
