Performance mods for 37s
4.56's would be minimum but 4.88's are going to be the ticket for those size tires.
  • Replies 68
6 hours ago, Frankielozano214 said:
I got 24x14 with 37s 13.5 24
(I had to cut the bumper more)
They say if you do mostly city get 4.88s and 4.56 if you do highway. I recently added a 2 in leveling kit to fix that issue. 4.88s are bad im pretty quick off the line and still retain about 12 to 16mph on the road depending on red lights and other cars. I also got a diablo intune i3 to fix some issues caused by the calibrator that was put on my truck. Interstate i can hit 85 easy just gets sketchy with these big tires
I would say 4.56 jus a little lower rpms im runnin almsot 3 grand around 80 or so
In regards to revealing the 9.76 rear end. Gear sets taller than the 3.73 will not fit on the 9.76 carrier. However, you can Go down to a 9.5 inch carrier and then use the taller gears that are made for the 9.5. At least, that was my experience when checking.
Yea thats where its get expensive. I say buy a tuner first then see how you like it. If you dont then spend the cash
That's what I did. I'm not going to regear my truck with 37's.
I went with a Superchips Flashpaq F5 tuner. I mostly got it for the speedometer correction but it does a lot more. It don't add much h.p.(maybe 15-18 on the 92 octane tune, at most but with the Borla catback exhaust it's probably more like 22-25 h.p.) but it did wake up the 5.3 at 3000 rpm and up. It did make the truck a lot more drivable.
My truck is mostly a mall crawler and I'm not racing anyone so it's just fine.
Yea wish I would've done that. But oh well you live and you learn
So not worth the regearing?
It's up to you Frankie.
How do you like it the way it is?
Do you have 3.42's?
Sent from my Pixel 3 using Tapatalk
Do you have 3.42's?
Yeah I have 3.42’s (that’s what my buildsheet says) it’s not bad but wish it would pick up alil faster, maybe after i install the exhaust and get a cold air intake
In my opinion no but I never tried a tuner first which would have adjusted my settings. I went on forums and listened to people who said regear or your truck is not going to last long. I talked a gm mechanic friend who told me dont do it but it was to late. Look at it like this $400 for a tune which you can easily take everything off your truck without any worries versus $4500 and you changed the mechanics of the truck which it will be harder to go back stock due to the higher gear ratio. Im no expert just trying to pass my experience along to others. At the end of the day its your truck your money
Damn I do see your point, might just hold off on regearing. Thanks for the info
Just so you know I have never heard a single person till now regret a regear once the truck is lifted. I also have never heard of someone spending $4500 for it to be done. The most I have seen is $3000 or the parts for $1200 and do it yourself. Regearing actually brings the vehicle back closer to stock. When people bring a lifted truck into the dealership shop myself and the other mechanics make a comment about how we hope the owner was smart and got a regear especially if on 37s. Tunes won't really do anything to help because of the lift and larger tires, except getting the tire size tuned in. You can't actually tune away the negatives brought on by the lift and tire size.
Sent from my SM-G975U1 using Tapatalk
lol I didn’t regret it (haven’t had time to get it done) , I’m just gotta hold off for now til I get some more spending money. I know a guy that does it locally close to Fort Worth for about 1500$ so i might give him a holla before I actually cut it out literally. Thanks for the info though definitely want my truck done right to were it doesn’t wear parts faster (transmission) then expected
On 3/4/2020 at 3:06 PM, Silver_rado said:
Yea eventually imma tune it
Brother you realize you have to get it tuned.. your truck still thinks it has the old gears and original tires on it! Lol I’m sure that like me you felt no difference what so ever with just adding the gears.. if anything it lags more.. you computer has to be told it can work better now because there is different equipment.. without a tune your transmission is technically miss-shifting and your losing power. I’m going through the tuning process right now with a custom Lew tune and a diablo tuner.. aaaand you’re not going to grenade your tranny now either so that’s a BIG plus! Lol I’m on 6’s & 7’s too just an inch or two higher.. you will not feel or see any difference till you get it tuned.. my boy has same truck, same wheel/tire size and same mods (regear, intake and cat back) but he has had it tuned and it is night and day driving his truck vs mine.
    RichardRS
    RichardRS
  • Who's Online   3 Members, 0 Anonymous, 836 Guests (See full list)
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
