Do you already have the Tow package?  If not, could be the wiring for the trailer...
If you do, could possibly be the trailering camera??
you got any pictures?
Are you looking at the hole to stick the crank in, to lower the spare tire?
1 hour ago, imadebogey said:
Anybody know what the plug behind the license plate is for?  I've searched but come up with nothing.
Could you provide a picture of the hole?
Makes guessing a lot easier.
I already put the license plate on.  I'll snap a picture tonight.  When I took the dealer tag off to put the license plate on, there is a plug just sitting there behind the plate with nothing plugged in to it.
Tow package, rear (back up) camera, and the LED lights mounted under the bed rails from the factory come to mind.
But take the picture, that way more might be able to help.
Already have the tow package.  I guess the trailering camera would make the most sense.
No.  It's not a hole.  There is just a plug hanging loose there.  I'll try to get a picture tonight.
I put my plates on over the weekend and didn’t pay much attention as my kids were running around in the street. Pretty sure I saw wires and a plug too. Was too busy yelling at my kids to get out of the street to take a good look. Now I’m curious. Will have to investigate.
Pretty sure it’s the plug for the wireless trailer tire pressure sensors. Had a look behind my license plate and there’s a black box there connected to that plug. Does your truck have the trailer tire pressure monitoring?
No it doesnt. That is probably what it is.
Sent from my SM-G975U1 using Tapatalk
Does it have a green plug? When I wired my Putco Blade tailgate lightbar using the Putco Blade quick connect harness I plugged into a previously unused connector.
https://www.putco.com/529005
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
