What tuning changes are needed to run E85 on the 2015 6.2
kgkern01
I am ordering the parts and sensor to run E85 for my 2015 6.2 today.  I plan on getting a full dyno tune with trans tuning etc later, but for now I want to just enable what I need to be able to run E85.  I know in HPTuners set Fuel Sensor to "Sensor" and FlexFuel to "Enabled", what else is needed to be able to run E85 on the 6.2 until I get the dyno tune done?
It is auto calculate for it and "work" but in tune you can clean it all up and adjust your ve based on the e85. Honestly you should just do it all at one time.
So I'd be better off just waiting until I can get in for the full tune and enable it then basically?
Yes. For hot you have to unlock the pcm and if needed also the tcm. So if you are paying to have it tuned or dynoed may as well have same guy do it. If is easy but still if you do not have ability to do it may as well let it happen at same time.
A quick rundown off the top of my head on non flex fuel vehicles.
Enable sensor.
Turn on sensor diagnostic.
Enable DTC trouble codes for sensor.
Setup the Flex Fuel settings in the tune. Stock is something like 10% min and 10% max ethanol content. I change the max to 85%.
Factory stoich table is set to 14.1, you need to copy over a stock stoich table from a flex fuel truck. The rest as said is done with a tune. Said tuner can adjust power enrichment fueling, flex fuel spark correction tables and lots of other stuff.
You can run E85 in it and be fine without changing anything. It’s not gonna blow up or break down.
run your tank down to empty. Fill up with E85 and head to the tuner. Let them do everything at once.
Enable sensor.
You work to hard. But you are correct in those items.
Won't running E85 in it without the sensor and FlexFuel enabled in the PCM cause a lean condition?
If you already have HP tuner and added a flex fuel sensor.  Here is a video on how to enable through HP tuner.
Pmoore4321 also has a video on how to add a flex fuel sensor for about 60 buck.  I did it on my L86 and it worked great.  I just had to move the sensor to the connection above the front of the tank.
Yes and also no. You need more e85 fuel to run. But the vehicle can't see that is is e85. But you have low and high octane so if you had knock it would drop into low octane. This is after it tried to add some fuel and then adjust(reduce) the throttle body to learn why it can't keep up. This is all assuming the power level of the vehicle is push the fuel that hard. But I would assume it would drop into limp mode.
Lots of buts and assumptions.[emoji17]
That is exactly what I figured would happen since the tables aren't currently setup for looking for E85.
Are you looking to strictly run E85? Thanks to “black02silverado” I’ve got an 18 6.2, SuperChips tuned to 91+, pump in about 7-8 gallons of E85 then chase it with 93. Never have any issues, very quick! Was quick to begin with but noticed a bit of snap here and there lol.
Sent from Above
It definitely won’t run all that good. Notice That’s why I said fill up with E85 then head straight to the tuner
Sent from Above
Just like him you gained nothing from running that fuel. It’s all in your head buddy.
    RSTRICK
    RSTRICK
  • Who's Online   5 Members, 0 Anonymous, 501 Guests (See full list)
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
