I’m wanting to have a front locker in my 2015 Sierra 1500. If I can just weld the gears that would be even better because Im a on a tight budget but I am a good welder.
From my research and understanding it seems like the front differential has a disconnect so that in 2wd a locker (or welded gears) in the front wouldn’t make a difference. It would only be noticeable when the center axle disconnect is engaged due to 4wd being engaged. Does this sound correct and does anyone have experience with this?
Also its on 35s and I know that the strength or the front end isn’t great and I would have to be very careful with a locked front end. This is also a daily driver but it seems like this would not effect anything while in 2wd.
I don't think it makes a diff wheither front or back. If its welded to rotate both wheels it will chirp/ skip in turns.
Sent from my LG-G710 using Tapatalk
It's going to pull to the drivers side.  With it locked and the passenger axle disconnected as it does you still will have load spinning the front driveshaft constantly on the drivers side that normally would just go the path of least resistance to the disconnected passenger axle. Since the carrier is locked to the drivers axle side it and the driveshaft will always spin where it normally wouldn't.  Guys have been trying this since 1988 and it's not pleasant.
It won't.  Passenger axle has a collar that connects the inner and outer portion.  In 2wd it disconnects so the passenger side freewheels.  It will however pull to the drivers side.
In 4wd it will hop and skid.
So in 2wd it will pull to driver side? Can you explain why? I don’t know a ton about differentials but I have a basic understanding. Why would it have a load spinning the front driveshaft? Does the open diff in the front allow the wheel to spin while the driveshaft doesn’t and then a locker would make the driveshaft and driver wheel locked together?
I understand how it would operate in 4wd and have no issue with that, it’s just the 2wd operation I’m trying to understand.
Your passenger wheel hub is freewheeling with zero resistance other than the bearing.  The drivers side is turning the gears and the driveshaft putting drag on it.  Yes it will pull to the drivers side.
When it's open all you spin is the spider gears and that disconnected passenger side axle....and not the entire gear set, front driveshaft along with the transfer case input shaft.
How noticeable will it be on your truck?  Do it and let us know lol.
Edited by SierraHD17
When it's open all you spin is the spider gears and not the entire gear set and front driveshaft.
Thank you. Do you know how hard it would pull? I wouldn’t think it would be very bad but I don’t have experience with it. And couldn’t you align it to pull to passenger side slightly to compensate?
Welding up the differential is something you do on a 20 year old mud truck, not a 4 year old daily driver.
You will regret it.
Drivability will suffer as noted above, plus, whatever you are doing with 35" tires that warrants a locked front axle is going to result in other far more significant failures. If your funds can't afford a proper locker, then they won't support the magnitude of repairs you will encounter either.
He can't even get an actual locker or limited slip of any kind for the 8.25" front as far as I know.  There is nothing available as they are so weak they can't handle it.  The 9.25" has a couple options but that's it.
for the rear
https://eastcoastgearsupply.com/i-20655114-gm-9-5-14-bolt-powertrax-lock-right-1950-lr-all.html
some people also fill the carrier with a bunch of lead and melt it into the spider gear housing, theres lots of cheap lead in dead old car batteries, this is reversable, just remelt the lead from housing
Edited by flyingfool
On 12/3/2019 at 6:21 AM, Jacoby said:
This thread should be titled “how to ruin a perfectly good truck”
that should be the name of the entire forum. lol
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
