2016 Duramax, what is the 1 position after the manual mode gear? Why would you use this gear instead of leaving manual mode in first?
I have looked through the manual(s) and did not come up with anything on a search.
That extra "1" is there on the gas trucks too.  I haven't seen an explanation for it.
It could be something useful like a gear indicator,  but apparently it's more important to just show a 1 all the time.
Off road going up and down hills in rough terrain it’s real handy. Although in 40 years of ROW work I didn’t need to that much.
Have none of you guys read the owner’s manual?
It enables the manual shift buttons on your gearshift lever. It will limit whatever gear you select. Shift into that mode cruising along at 60mph, and it will show 6th gear. In the older trucks, it was shown as  “M” instead of “1,” which makes a lot more sense to me.
Edited by Icutmetl
No that's not what they are talking about.  The indicator is PRNDM 1.  The lone "one" position disables the buttons on the shifter and keeps it in first.  It also works as grade braking control lol.
If I pull the lever down to the 1 position at any speed on my 2016 gasser it will shift to the lowest allowable gear for the speed/rpm and hold that gear.  (I say any speed, but I have only tried it at speeds less than 45 mph.  It downshifts quickly.) The manual shift buttons do not work with it the 1 position.  If I start out from a stop with it at 1 it stays in first gear all the way to rev limiter and does not shift.
I can't seem to find anything about the 1 position in my owners manual either.  There is a paragraph or so for each of the other shift lever positions but not the 1.  The only time I have used the 1 spot is on the beach when in 4WD Low and I want to idle along through the loose sand.
I seem to recall there was another thread about this topic a couple years back and it got pretty much the same replies as this one.
Correct.
When you're at speed and in a panic and need max engine/trans grade braking but got too much going on to mess with the +/- button, just grab the shifter and pull it into the '1' position.
If it's just pulled to Mx (range selection mode in GMspeak), the gear it shifts to depends on the gear that it is currently in -- there is are charts in the manual for each transmission.
The gear that it shifts to will be displayed in the blank location between the M and the 1. The displayed number will be the max gear the transmission will use -- unless the +/- is used to change it, or until the shifter moved out of Mx postion.
Sierrahd17 has it right. It works amazing as grade brake control. I use it often when towing our rv
Sent from my SM-N975W using Tapatalk
There is both a 'normal mode grade braking' and a tow/haul mode grade braking'.
Running in Range Selection Mode (M mode) disables the grade braking.
There may be times when the computer managed grade braking are not desired.
OM has slightly different explanations for the gas engine and diesel engine trucks.
Edited by redwngr
I use manual mode when towing our camper as well (especially in the Colorado mountains)......but I've yet to find a use for the "1" mode, which holds the transmission in first gear. How about you?
If you just wanted to slink along at a slow pace, the one position in 4 low is kinda like a creeper gear on a tractor. You could get out and walk beside it without it shifting into second and making you trot.
I do that sometimes on the beach way up in the dry sand.  Well, I don't get out but I use the 1 position in low range.  My trotting days are long past.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
    • So, lot's of googling and reading, and a trial fit found, that indeed they hit the newer fatter caliper. I did some re-testing today, and found just 3/16" worth of washers was enough for the wheel to spin freely. I added 2 more on each, and again it spun freely. Tested lock to lock with the 4 washers, about 5/16" not quite the 3/8" Im considering, but pretty close. No issues. I've been looking at the BORA .375" spacers and using extended lugnuts to get back lost thread due to the spacer. All the ET lugs I've seen are all .33" reach inside the wheel lug holes. For those that don't like spacers or think they're unsafe, I think it depends on what type of spacers you're using and making sure you get good quality hubcentric ones, and if you're using bolt on ones, regular mainenance, checking the spacer lugs. Not wanting or needing that much spread. Looking for the minimum that will let me run these rims and tires.  it does look to stick out a little, but I really want put these on. and use the stock all-terrains in the winter.
