Awesome. I would not do the additional lift upfront, personally. I don’t mind the rake. Dealership install it? I was looking at that kit.
The 1” won’t level it, I left some rake so it isn’t nose up when I tow or have a load. It just limits it a bit.
I did have the dealer do the install, I get to use my reward points...
On 2/4/2020 at 8:37 PM, AEmedic said:
Thank you!  It is the GM TB 2” lift with an additional 1” up front.
Are you running spacers on the factory wheels?
Nope, no spacers.
Nope, no spacers.
Thanks, just put my lift on this weekend and I’m leaning towards the 35x11.50 on factory wheels.
60408993294__2BE491EE-9B31-46EA-9094-CF32FC8C4A72.JPG.f50d919bb186b07e5dd8a943f9889c11.JPG        Installed my red CHEVROLET tailgate letters today. Went with the domed style from BDTrims.
Bumpy McBumpster! heres my Northsky truckinator!!!
Mike :)
The more I see this color, the more I love it! I just can't wait to do something about these wheels!
Do what with those wheels?
Replace them with something chrome. I'm debating between 20 & 22 inch wheels, either would be the same style you have, because I really like those wheels as they are more 'sport' wheels than the wheels that came from the factory, which are more 'off road' style wheels to me.
I got a perfect set of 22s for ya......[emoji6][emoji108]c823b269e14849cfb1c0619131c34288.jpg
9 hours ago, kwOH said:
I got a perfect set of 22s for ya......emoji6.pngemoji108.pngc823b269e14849cfb1c0619131c34288.jpg
What wheels are those?  I can't tell from the angle.
thanks
    LCH14
    LCH14
  • Who's Online   3 Members, 0 Anonymous, 1,647 Guests (See full list)
    • I'd change the fluid and start there.   198F is nothing for the 8L90.  They typically operate 180-200F stock.
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
    • Your truck lowered, looks good. I'm happy with the stance on this. I may need the extra ground clearance given my location/situation.
