Linkswell 12.1" Gen 3
Just installed this system in my truck. So far so good. Looking for any tips and tricks. Any info is appreciated.
I didn’t know those even existed.. I’ll be watching this one, for sure..
You have total connectivity across all factory menus.?
What trim level/year did you install it in?
Looks interesting. Especially the "upgraded rearview camera" would be a great feature. How did you solve the issue with the bluetooth microphone? Can you fit it "hidden" like the OEM one?
Are you so far satisfied with the handling/response time in cold/hot temperature?
What trim level/year did you install it on?
I installed this on a 2018 LTZ.
List of features not retained:
XM radio
HD radio
CD Player
Driver Information Center radio & navigation displays
Factory rear entertainment
Factory rear controls
XM is easily replaced by the app with hotspot or wifi. So no loss there. Radio is the same with apps. I never onced used the cd player in my truck. Not too concerned with the driver info. Haven't installed rear entertainment. So for me, I didnt lose anything really.
Everything works as it should, sound quality is great. I did have yo purchase the Bose amplifier box. Navigation is way better as I also purchased the iGo license. So far everything is great. Install was easy, plug and play. Satisfied greatly so far!
I put the mic where they suggested in the install video. I may look for other alternatives in the future. Have a few ideas. Response time is good as long as you're not trying to do everything at once and run a ton of apps constantly.
Why not just splice into the OEM mic and run the wiring for it down the Drivers A pillar cover?
or buying a second "factory" mic and installing it right next to the original (assuming tampering with the original could alter how OnStar works..)
All good ideas. But I will shoot those guys an email before doing any splicing. I wouldn't be surprised if theyve already thought of yhese things.
often enough the people that create these types of plug and play systems aren't interested in splicing at all, which is why you've got harnesses including 4-5 rca connectors that are going unused on a stock Bose install.
dont get me wrong, I love the idea of having a tablet style head unit, but not at the cost of sacrificing sirius/hd radio/cd/dvd/etc. plus all the drivers information center integration.
looks great, but I'd just never go through with it until they offer an integration with fewer seams.
For me, Sirius and radio is solved with my unlimited data plan and the apps. CD, I never used once. DVD, is actually better for me as I can play multiple formats on the tablet. As far as losing the music part of the drivers info center, thats really no big deal considering theres a 12" screen in front of me.
Yes, I would love to see a 100% plug an play with no features lost. Maybe on day. But its all about what you want and what you're good with. Im ok with this. It works better for me and my wants!
  • 3 weeks later...
I just posted about this unit. Not bad for the price considering a apple carplay upgrade is 200 less. I am gonna try building my own tablet to work and make it removable to access the original screen when needed, or relocate the original screen. Keep us updated on how its working, curious on longevity.
Sent from my SM-G960U using Tapatalk
  • 1 month later...
On 1/7/2020 at 12:30 AM, patrick taylor said:
steering wheel radio controls work?
Yes, steering wheel control work perfect.
My buddy did this in his TBSS back in the day. Had a custom dash bezel that allowed his iPad to slide out the side. He worked for a mobile audio place at the time and it was a process, but the finished product was pretty sweet.
Sent from my SM-N975U using Tapatalk
I tried the tablet route. Didnt like it. Swapped out for a whole new head unit.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
