I doubt anyone has changed their fuel filter yet but if they have are you having trouble resetting the fuel filter percentage on the computer?  Mine won't reset to 100%.
You are doing this "To reset the system,press and hold the thumbwheel fortwo seconds while Fuel Filter LifeRemaining is displayed on the DIC."?
What happens for you when you do?
I did that and also 5 seconds or longer and it beeps but nothing happens.  When you press the wheel it switches over to the confirmation page that asks if you want to reset it, I select yes and it stays at 28%.  When I hold the wheel down for any amount of time it beeps but doesn't switch to the other screen.
On my 18, you had to press the center button and hold it for 5 seconds.  After the beep, stop pressing the button and cycle the key.  Then it would reset to 100%.
With the push button, I would presume it's all done the same.  This was all done without the engine actually running though.
Unfortunately you can't actually get to that menu if the truck isn't running on the new ones.  I've done what the manual says and it won't work, so I'm assuming there is an issue.  Looks like it'll be another trip back to the dealer.
  • 10 months later...
I finally got this figured out in my 2020 hd....you have to push and hold the steering wheel toggle button down for a few seconds and then it will beep...the percent will remain the same...shut the truck off and turn back on and it will reset...pain in the A.
if you have push button start: hold the start button (without foot on the brake) for 5 seconds. that will put the truck into run mode without the truck running. then reset the filter. turn the ignition off and it should be reset on next power up
Thanks. This worked for me finally. The dealer wasn’t even sure how to do it. Lol.
i took my 2020 silverado 2500 diesel to the dealer today and had the fuel filter replaced.  They couldn't reset it.  So I got on line and notice your email.  It worked great.  hold the start button for 5 seconds without touching the brake pedal.  then when in accessory mode push in the center button on the right side for 2 seconds and it immediately went to 100%.
thanks
  • 3 years later...
thanks kylant just found your old post, had this issue after changing filter myself & DIC wouldn't reset, my '22 2500 Duramax reset immediately following your advice.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
