Life expectancy of unused engine oil?
TXGREEK
  • Replies 47
2 hours ago, elcamino said:
ExxonMobil recommends a five-year maximum shelf life for engine oils,
Same thing with "canned" goods, such as when they (commies) demonized BPA, the ability for a container to keep foods fresh was greatly diminished.
BPA is a chemical used only for plastics. And I've never used plastic for storing food anyways because plastic makes food taste like plastic and the plastic container whether containing BPA or not actually diminishes food quality. Use glass containers and food stays fresh longer and will actually taste like food. But let me not detail this and keep it on topic with oil storage since the oil is not edible anyways, Lol!!
Sent from my Pixel 3a using Tapatalk
The better question is the shelf life of an opened container of oil...
This is exactly why I started this thread, these containers are NOT sealed, they’re capped off, oxygen easily enters the bottle. So, how long does opened oil last when re-capped??
Sent from Above
Well, they used BPA in the lining of cans for decades and of course in plastics.  Whenever someone says something such as this causes dozens of ailments, you can almost always rest assured that they are lying and have some nefarious agenda.  There's nothing wrong with BPA.  We use lots of jars, but also have kids and do not like glass in my toes!  Refrigerated goods get plastic in our home; for now.
Ah ok, got it!
I only buy Mobil One Synthetic at Wally world ($22 for 5 quarts typically) but it is always foil sealed under the cap.
Sent from Above
Made me think now about those 6 quart Havoline bags in a box that I bought. I wonder what the shelf life on those would be compared to a plastic container? The caps seem very different than the caps on plastic containers. They have a seal that kind of looks like some sort of gasket.
Made me think now about those Havoline bags in a box that I bought. I wonder what the shelf life on those would be compared to a plastic container? The caps seem very different than the caps on plastic containers. They have a seal that kind of looks like some sort of gasket.
Never seen that, can you post a couple pics? My Amsoil has transmission fluid in that type of bags but I’ve never seen motor oil in a bag.
Sent from Above
Sent from Above
It's a 6 quart bag in a box:
29a531e21a94321a38de53fe2e6cfa8b.jpg2bda0a1f4d70c9067a7acd336a1a2732.jpg07c880bddc398a5bd4dc325ff8de0e85.jpg
Interesting, never seen that other than Amsoil. Looks to me you’re going to have a messy application unless you’ve got a wide mouth funnel. You’ll have to let us know how affective using your setup is versus plastic quarts.
Sent from Above
Sent from Above
I bought a crapload of them at $17 per box so whether it's messy or not, I'll have to figure it out, Lol!! With the wide funnel it should be ok I'm sure. I also thought of transferring to an empty quart and then into the truck. I'm waiting for my Fumoto valve to arrive so I'll be doing the first oil change next week. I'll post results then!
Groovy, wishing you and everyone else a kick ass Christmas! And I’m not saying this just cause we’re apparently part of the badass CST Lift Cult, lmao!
Sent from Above
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
