Nice! I love my double cab.
Those tires look real sharp, makes the truck look very aggressive! Might be an option for me when I'm due ?
1 hour ago, Old Farfegnugen said:
Beautiful truck, tastefully done.  I like everything you've done.  Those running boards and tires are especially nice!  :thumbs:
Thankyou, much appreciated...!!
So you're not using the Readylift 2 inch level now ? I ask because I'm in the market for one and could possibly be interested. TIA
No I'm not. I wanted my truck a little higher without going a 6 inch. Sorry tho, I already sold it weeks ago in the classifieds here.
On 12/27/2019 at 6:29 PM, Flatblack83 said:
Readylift 2 inch level, 295 60 20 wildpeaks, painted mirror caps, stock led for lights, morimoto low beams and a tri fold toneau.20191107_161858.thumb.jpg.e4722ebd522003fcfc4309d98b2bdb94.jpg20191107_161846.thumb.jpg.d5396897b2a2b21d571b4820a3c33e5d.jpg20191226_192352.thumb.jpg.e7351502aef39606a6be3df353d7e01f.jpg
Where'd you get the morimot low beams. I've been looking for some olug and play LED bulbs and did you need t get an anti flicker?
https://www.theretrofitsource.com/h11-led-headlight-bulbs-morimoto-2stroke.html?preselect=54761%2C49229%2C54671
I bought the anti-flicker when I got mine (just in case) but honestly they are not needed and will likely prohibit you from using the headlight caps to keep moisture out.
I havent noticed mine flickering driving it at night so I didn't buy the anti flicker. They seem fine to me.
@Flatblack83 I just had the ICON stage 1 kit installed on my 2019 Elevation Double Cab - with the front set at about 1.5" level. Loving the kit & how it rides.
But I'm finding that the the it wanders a bit at highway speeds & the steering is a bit dull. What has been your experience with steering? Do you still have a copy of the alignment report?
Thanks!
Thanks!
Actually mine drives really well, steers n drives great. Also handles really well.  A little firm over the bumps with our fine pa roads.  It was aligned to factory specs at the dealer by a buddy of mine so I dont have a spec sheet. How much preload is on the coilovers..? Do u have a pic..?
Edited by Flatblack83
My experience is about the same with the improved handling (also on PA roads - had the kit installed in Dover, PA). Its about 4-5 threads above the spring collar (haven't taken a measurement - but just eyeballed it). I'm assuming it came set that way from the factory. Does that sound right to you? I'm still learning....Will take some pictures tomorrow
On 1/15/2020 at 6:26 PM, Flatblack83 said:
All cleaned up, ready 4 Saturdays snow fall. Heres the newest if the stance with the side steps.
Truck looks sharp de badged for sure, nice
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 561 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
