My truck was leveled out at about 1.5”. It actually sits 1/4” higher in the front right now, so I’m due back at the shop on Monday for a re-torque, final measurements, and any other needed adjustments. I actually stopped by the dealership yesterday & got a copy of the recommended alignment specs for my specific vehicle. I was curious to see how it differed from alignment after the kit was installed. So there are some slight discrepancies in caster and toe. The steering kind of settled in over the last day, but I feel like the steering is stiffer than what it used to be, prior to the install.
Anyway here are some pics of how it came out. It’s sitting on a decline and looks good. It’s only when I park it on a bit of an incline Does it begin to look nose high & so I begin to wonder if I should have them bring it down to 1” of lift in the front. It’s weird with the GMCs because of the way the wheel well is designed and the aggressive grill, with the slightest lift It looks nose high.
After about 1k miles and hearing other people's reviews on these icons I figured I'd call them. My truck rides too firm for my liking but drives really well. I was told the non reservoir have spacers inside to limit travel. It would need to be removed. So instead I turned all the preload off the coilover and put a moto fab 1/2 inch spacer under it. That pushes the shaft up off of the internal spacer giving more room. So far so good, still at 3 inch lift and rides smoother.
6 hours ago, Kableguy said:
Jtlans- what tint did you go with on your windows? Getting mine done soon, yours looks good.
I am uncertain. I just took it to a local tint shop and just told them to match it to the rear. I would guess that it's 15 or 18%.
I have a 2020 Custom that I have done a few things to. A before and after comparison is attached.
Wow! Very classy!
On 1/15/2020 at 5:26 PM, Flatblack83 said:
All cleaned up, ready 4 Saturdays snow fall. Heres the newest if the stance with the side steps.
This is a really really good looking truck. Love the colors, wheels, lift steps, all of it. Well done sir
The led fancier truck style headlights with the drl have grown on me. So I'm going to do a change to the front end, I bought a set of led headlights, black grill and a wiring harness. Hopefully I can do this in about a week or so.
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   2 Members, 0 Anonymous, 684 Guests (See full list)
