Markus Escamilla Posted December 30, 2019 Posted December 30, 2019 On a white paper towel my transmission fluid is light brown. I have been debating on whether I should change it or not because people tell me that it will stop shifting good. Should i just change it and add some lucas transmission fix?
riverbanks Posted December 30, 2019 Posted December 30, 2019 Change it, just do filter and replace lost fluid,safe that way,not dislodging anything
Markus Escamilla Posted December 30, 2019 Author Posted December 30, 2019 Would it be a good idea to add a slip additive as a precaution?
Mikebtte Posted December 30, 2019 Posted December 30, 2019 No, I would add nothing. The reason a Flush is a bad idea is because some shops use old fluid to flush and you end up dirty than when you came in. If new fluid is used to flush a transmission you will see no issue. I would recommend if you don't want to do a flush to drop the pan, put in a filter and fill. After a week do it a second time and you will be set for a while.
Grumpy Bear Posted December 30, 2019 Posted December 30, 2019 6 hours ago, Markus Escamilla said: On a white paper towel my transmission fluid is light brown. I have been debating on whether I should change it or not because people tell me that it will stop shifting good. Should i just change it and add some lucas transmission fix? What's the debate? Shift quality going away by replacing damaged fluid with fresh? What are you trying to 'fix' with the Lucas if it's already "shifting good'? Fresh fluid will not deteriorate shift quality. EVER. The method used to do so might. If it shifts good now Lucas wont do anything. If it shifts poorly nothing short of a rebuild is more likely the answer than fluid magic. Thing is, it isn't likely to hurt anything either. so.... Simple pan drop, filter change and refill with the correct fluid. Some shops can kill a trans with a flush, some will not. You have no idea who is who. Right?
carkhz316 Posted December 31, 2019 Posted December 31, 2019 5 hours ago, Grumpy Bear said: What's the debate? Shift quality going away by replacing damaged fluid with fresh? What are you trying to 'fix' with the Lucas if it's already "shifting good'? Fresh fluid will not deteriorate shift quality. EVER. The method used to do so might. If it shifts good now Lucas wont do anything. If it shifts poorly nothing short of a rebuild is more likely the answer than fluid magic. Thing is, it isn't likely to hurt anything either. so.... Simple pan drop, filter change and refill with the correct fluid. Some shops can kill a trans with a flush, some will not. You have no idea who is who. Right? Get outta here with your logic, ahhahaha j/k. Good points........x2
OZRY83 Posted January 2, 2020 Posted January 2, 2020 I myself don't like flushing because it can stir up anything that's sitting in pan. I pull pan clean it out if reusing it. Like to replace the stamped steel pans with cast, one with cooling fins and a drain plug. Change out filter and put all back together. This only drains a few quarts of entire system, theres still fluid in cooling lines to radiator and whats in torque converter. But if you do like above and drive it a week or so , drain again and replace fluid it will be cleaner.
