Does anyone know what the specs are for USB-C in new trucks?  I connected a gas charge USB-C to lightning and connected my iPhone X and it doesn’t fast charge.  I also connected my laptop and the power was not enough to keep up charge while on
Correct me if I'm wrong, but USB C & lighting cable don't necessarily mean a fast charge.  They mean faster data transfer speeds.  Fast charging is based on high amp output at charging source.
Manual mentions the wireless charger provides 3A...    I don't see any mention of the specs of the wired ports though.
If you are looking for fast charging, I would suggest getting a 12V accessory plug, or something to go into the 110v outlet...
I bought an anker usb-c to lightning cable and my iPhone X charges way faster than the usb connection.
  • 3 years later...
I'm a bit surprised that this specification is not known.  Seems a bit ridiculous that it's not specified in the manual. Any random USB C part (even $4 cables) have a started max wattage. I use a 12v adapter to get 65w. I need 65w for laptops. It also works just fine for phones and tables. A 65w adapter now costs only about $12. Wish I didn't need the extra adapter in the clutter, but I do. Now I heard the 2022 and later trucks do not have a 12v outlet! So the ability to use a 12v adapter is gone and the USB c wattage is sh1t. What were they thinking m
  • 1 year later...
I have a 20 watt amber strobe light that has a cigarette loghter adapter on it. my new Silverado 2500 does not have a cigarrete lighter plug. I cant find an apter for USB-C yo cigarette lighter that supports 20 watts. the specs for USB-C state it can supprt 100 watts. I assume (you know how that goes) that the plug in my truck will suppoet that too, but i cant find those specs anywhere...
I think strobe lights are battery-operated nowadays...
LED's don't require much energy.
The USB-C in my Cheyenne did around 10W, that's just a wild guess. The regular USB did 2 or 3W.
Yes -- and often usb for charging.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
