Courtesy Light Problem
I have a 2017 GMC Sierra SLT. The courtesy lights will not come on when opening passenger door. It works with the other 3 doors.
Does anyone have any idea what could be the problem ?
Did you check the door switch? I'd start there and see if it is broken.
Welcome to this forum!  NCPGMC provided the most logical starting point to diagnose the problem.  I would assume this step would have preceded posting online(?)  My first thought was related to moisture and freezing but your ID doesn't mention your location.   The more information you provide, the more helpful the response.  Good luck!
Where is the switch located? There is nothing there that could be a switch.
I live in south Louisiana so freezing is not an issue . If I look on door jamb there is nothing that can be considered a switch
The switch is in the door latch, I think they started putting them there on these trucks since about 2000.
