1 hour ago, bradman0087 said:
Whats the trick to remove the front tow hooks on 2015 GMC Sierra Crew Cab?  going to paint them red..
I understand they are a pita to remove.  I'd be inclined to paint the exposed portion without removing them from the truck!
You either need a cut off wheel To cut one of the bolts or to remove the bumper to get the driver side tow hook off because of the way they put one of the bolts through.
wtf  ... why make it this complicated.
Why make it easy??
Buy a set from GM, only around $100.00 and the quality is very good.
I have a set (one) on my 18 and it does not even have a chip in it.
Removal will require cutting the drivers side bolt, passenger side is pretty strait forward. If you buy a set from GM, they come with all new hardware.
Edited by JimCost2014
Not a big deal to cut the one bolt that is blocked. I spent way too much time trying to find an alternative way to remove them before just cutting it. I bought a spare bolt and now I can take the tow hooks off in a matter of minutes. Either a cutoff wheel or a reciprocating saw will do the trick.
Cordless Makita Sawzall did the trick for me.
If you do not mind, how much to powder coat them, and what type of finish will it be?
If you do mind, how much to powder coat them, and what type of finish will it be?
I painted mine with engine enamel. Colour and finish turned out great but after a few months its not holding up that great. Interested in what folks are paying for powder coating.
Yeah engine enamel has almost no UV protection so a couple month seeing sunshine and weather is going to break it down super fast. As far as powder coating to tow hooks it’s probably going to be whatever the shop minimum is unless you’re getting them in some strange color that they have to special order. Around where I am that’s between $75-$100 depending on where you go.
Check Ebay for powder coated ones. Before I bought my GM red ones I was considering going white. At that time there was a guy selling different colored ones for I believe 60ish a set.
On the 014/015s anyway you can remove them without cutting the bolt or removing the bumper. There is a thread on here somewhere with the youtube video on how to do it. Basically you loosen the bumper bracket that’s in the way and use a pry bar to move it enuff to get the bolt out. Then when you put it back together reverse the bolt or replace it with a shorter one like stated above.
thread with video
Edited by wforrest08
I have never needed the tow hooks and most probably wont ever need it so i plan on geting rid of them and putting in LED cubes in there vs a light bar in the grill.
I seen that done and looks clean.
What would you use to connect it down there?
Sent from my Pixel 2 XL using Tapatalk
You would have to get down there and see what you can DIY as a mount.
  • 1 year later...
Just removed mine from a 2021 with additional cowling further obstructing the drivers side bolt,  had to bend up the bumper bracket to allow the bolt to be removed. Was just going to paint, but after all this trouble might as well powder coat
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 528 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
