Rides great on pavement and good condition dirt roads..tires aren't too loud. I haven't been on anything major offroad yet.
I ordered some brackets that replace the hole where the mud flaps go. Took them out due to the slight rub there. Also looking into some fenderflares due to the poke. That's one reason I haven't gone all out on these gravel roads in Texas yet.
Did the Ready Lift 2" SST level kit on my 2019 AT4 Carbon Pro - lost use of "auto 4WD" as RL does not recommend use.  I just traded it for a 2020 AT4 Carbon Pro to get trailer tow mirros and new trailer tow camera tech - as I tow fairly often.
Going with BDS 2.5" kit with Fox 2.5 DSC coilovers - figured might as well do it right this time!
Looking forward to the upgrade - hope to have it install in a few weeks!
link:  https://bds-suspension.com/kit-customizer?kid=754F
And if that doesn’t work are you going to trade it in for a 2021 and then try again ?
Why not - LOL!    The 2020 with tow mirrors, cameras and BDS suspension is awesome!   Could not be happier with the overall package.
  • 1 year later...
On 1/24/2021 at 10:32 AM, Supercup said:
Turned out great!  Thx for the update on the wheels and tire sizing - very helpful.  Next step for me to swap out my current methods for one's with -12mm offset, like you got - gives me a great guide for tire size - probably go with 33/12/5/18 BFG's.
How do you like the ride and performance now that it is installed?
Sorry to bring back an old thread, but I'm currently in this predicament and this thread is one of the only sources I can find in the topic.
I'm looking at the CST 4.5" lift. I have 18" stock wheels (18x8.5, 26mm offset, 5.77" backspacing). The kit says it only works with 20" wheels and max 5" backspacing due to tie rod interference. I'm hoping to run my 18's by using 1.25" spacers (4.57" backspacing). That should work right??
  • 3 years later...
Bummer I can only find these old threads regarding BDS lifts. I am looking into the 2.5" or the 4" but there is nothing out there accept videos showing them on, no real review or hard measurements.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
