I know.  I know.  My 81 year old father in law wants to order a new AT4 because of the way it looks but has a hard time climbing in and out.  The truck will be on the highway 99.999% of the time and if it ever is off the pavement, it will be a gravel road.  I tried to talk him into the Denali but he hates the chrome and the cost of the AT4 parts to make the swap are stupid expensive.  Does anyone know how GM achieves the 2" lift and can it be reversed?
Curious of this myself. And im the same as your father, hate chrome, love the look of the at4. Due to a back injury from the military, there are days that getting in and out are a challange.
I think basically it is different shocks/struts, blocks, and front axles. You could easily remove the rear block and change the shocks. Not sure on the impact of the front axles with lowering.
GM also offers a 2" lift kit thru accessories.
Have a look at the kit --- it will show what is changed.
Has he looked at an Elevation in a colour he likes?  Might be a lot easier than removing a lift.
Maybe a Denali and change the grill and/or grill surround or an SLT and vinyl wrap the chrome bumper?
Thanks.  I looked at swapping all of the various trim pieces and the cost was astronomical.  Best estimate from the body shop I trust was over $6500 parts and labor.  I can't imagine the cost of the lift kit installed will be more than half that.
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
