The code has changed slightly so the steps for changing line 151 isn’t correct anymore. With every uodate from the developer, it changes so i will dm you.
i have the 8 speed auto in my 2018 I will probably never tow anything but a baby carriage with it sweet truck but I did not buy it for towing. 4x4 decent gas mileage, just learning how to drive with the 8 spd. it's cruise control on the freeway, and manual shift of the back roads.. the 8 spd is the soft spot.
on my 2000 silverado i could push the domelight over ride on and off twice and it killed the headlight. oddly enough, there is a little trick for everything.
I hear ya. I remember the air cooled trans. My deal is, I`m not one to run my trans at 212 "to get the water out". If you leave a cold beer out on the bar, will the condensation go away without boiling?
I don`t believe in the not hot enough to shift properly or to get the water out. A trans will fail in 2 ways. Either you break it or you roast it. How many have failed from being "too cold"?
Oil viscosity? Hmm. How much "thicker" does an oil get as it gets saturated with clutch particles? When it`s time for me to change my 10L80 oil, it will get LV spec oil.😮 Lets see what happens.
