4 hours ago, VicFirth said:
Guess I'm the ant at the picnic. :) Let me say this up front. Good points all.
Now, having said that, let me toss this out there. SYNERGY
It isn't this or that. It's this and that and that and that. There is no perfect base. There are some darn good blends. There are some that are basic. Some worse. A few much worse.
There is no perfect add pack. There are add packs that work well with specific blends of bases.
There isn't a Nirvana. There is best KNOW current compromise.
What works against this is PROFIT MARGINS. Greed is obscuring the truth.
Mobil tossing POE under the bus was not a performance move. It was a profit move. They have been in and out of the Tri-synthetic market (PAO/POE/AN) more often than Uncle Vinny in a $20 hooker.
Dad and Uncle pushed Fords past 750 K and to a MILLON on straight cut dinosaur oils on REALY SHORT OCI's.
Matching a chemistry to an OCI is key.  The fight is over OXIDATION (OCI) not wear. 90% of the public doesn't even care about wear rates. They trade to often and don't give a rat's back side about the next guy. Puppy Pee with get you to 60K.
:rant:
Edited by Grumpy Bear
  • Thanks 1
:rant:
You had mentioned in response to my longevity question about changing the engine once it failed. You’re answer was the body is giving up do to the winter in your area. It sounds like a daily driver in your neck of the woods is good for 8-10 years max. Probably 200K miles for most people. 5K oil changes with most any synthetic will do the job. For most vehicles. The general feeling across the board is most vehicles will reach 200K miles sold today. Even after all your efforts it seemed you had an oil burner after 100K miles. I wonder if it would have made 200K if you did nothing but added oil.
I'd like to see this granular of a discussion about gasolines and diesel fuels. Then look at what they do to our engines that our oils can't correct for.    Grandaddys fuels and their post combustion products were not recirculated into his engines, they went out the draft tube. Remember the dark part of the blacktop and concrete that was in the middle of the lane???? That's were all that crap went we now re-ingest.
My last collector vehicle was a 64 elcamino. It had the canister oil filter and that tube. You could smell the blow by. We still have a 2000 Ford 7.3 and a 98 Ram with the Cummins. My mother just passed 240K miles with it. They both have been bulletproof. All free of the latest emissions. Both get better fuel mileage than the current models. My brother has about 6 newer Ford and GM diesel for backup for his ROW crews. He used to keep two around. Non are as reliable with the latest emissions. There’re different animals after being deleted.
I agree Grumpy synergy is key.  There is no chemical panacea.
Mobil 1 has excellent oxidation resistance.
Edited by VicFirth
If you recall a UOA at 80K showed the motor was 'eating" itself. Iron. Aluminum. Stuck rings. Simply adding oil would not have freed them and the destruction would be complete and in shorter order than long. Lack of ring seal drastically shortens oil life and my response to that was a drastically shorter OCI. Again, based on UOAs at the time. Viscosity break was horrible. So, if I had stayed on 5K OCI's and simply added, this motor would have mechanically failed well before 150K. A lesson learned in my teens (first few cars).
Pepper is now 9 years old and as solid as she was the day I bought her, 180K pretty soon. Very different life in the exact same environment. Daisy is 16 years old and will pass for new even in the nooks and crannies. Last thee Hondas went 18 to 20 years before the body died. All in daily service.
We've been looking at a replacement for Dizzy and it has been heartbreaking. I am rapidly coming to the conclusion that I can do the repairs required and be half as deep in cost and get twice the vehicle as a result. Including the body work.
  • Sad 1
Fuels would be a really interesting topic to dive deeper into IF we had the choices we have in motor oils. And I guess to a certain extent we do. We just have less information to work with. I have one Flex Fuel capable vehicle and I use E85 in it. The remaining ones I use Top Tier and occasional PEA or Propylated, Aminated systems cleaners. Techron, Red Line S1, AMSOIL P.I., GUMOUT Regane.
Sidebar. As a motor ages and ring seal fades and inlet guides weep oil ingress to the power cylinder increases the octane requirement. Not due to carbon build and compression pressure increase, although that can be a player, but because oil mixed with fuel KILLS octane rating. 😉  ECU KR response can only take out so much timing.
I’m probably happily stuck with my avalanche for life. I keep looking, that never stops. If I find a nicer one for a reasonable price I’d buy it. Same with the other two. I can’t believe how well my wife’s car has aged. I’m in good climate so that’s not a factor. I’m good with hanging on to them now.
There is no oxidation issue in current spark engines. There is less oxidation issues in compression engines.
Nitration yes. There are no good anti noxidant additives but the oil and chemistry industry want you the consumer with a bit of knowledge about oil analysis to believe anti oxidants which are cheap really matter. Food for thought. More marketing crap.
  • Thanks 1
  • Haha 1
Very interesting.
  • Sad 1
On 5/11/2024 at 9:45 AM, Grumpy Bear said:
Mobil Oil on Nitration:
Once again Grumpy you are posting info on BURNING METHANE via spark engines.  Not applicable necessarily to our engines using gasoline or gasoiline ethanol mixes.
When I worked for WOO sprint car race series as the oil analysis rep and we burned methanol in our 410 engines before switching to ethanol we had a separate set of issues.
You can't just go to interwebs and pull spurious unrelated tech data to prove your point which is based on lack of R&D level knowledge.
Gosh I sound smart again, the meds are working....better living through chemistry MOFO's! Story of my life.
Learn for yourselves kids.  Take an oil analysis from any cheapass source you can find that can keep their FTIR tuned accurately. ( check out RUSH truck centers for a cheap source but make sure the techs and mechs haven't kicked it or blown cigarette smoke into their little box size analyzer before they run your sample)   Sample your engine oil brand clean and run against a used sample looking at NITRATION vs OXIDATION  tell me which one shows movement purely via starting value vs ending on used.   Thats not an accurate reading via science interpretation but one that will convince.
Nitration ambient clean will NOT carry over to a fired engine oil .  So consider starting nitration 0 on clean oil via FTIR, Near IR, or Raman.
Oxidation ambient is a measure of clean oil construct but the used value won't rise much more than 5 abs units because oxidation is low in modern engines first and secondly oxidation phase inhibiters are so cheap and effective they will neutralize any harmful oxidation until the oil is overused OR there is a serious fuel or mechanical issue.
  • Thanks 1
19 F-150 3.5EB, 14.4k HPL No VII Euro 5w30
14k miles on HPL No VII Euro 5w30.  My question is, if the virgin oxidation value starts at 23 for this oil, but is now 48, is that a problem or sign of oxidation?  I have noticed that Amsoil's virgin oxidation number doesn't change much from virgin to new.
SAMPLE INFORMATION Unit of Measurement Reject Limit Result
Sample Date     03 May 2024
Machine Age miles   82988
Oil Age miles   14394
Oil Changed     Not Changed
CONTAMINATION
Fuel   >4.0 <1.0
Water   >0.2 NEG
Glycol     NEG
WEAR METALS
Iron ppm >150 29
Chromium ppm >20 <1
Nickel ppm >5 0
Titanium ppm   <1
Silver ppm >2 0
Aluminum ppm >40 15
Lead ppm >50 0
Copper ppm >155 11
Tin ppm >10 <1
Vanadium ppm   0
Cadmium ppm   0
ADDITIVES
Boron ppm 200 53
Barium ppm   3
Molybdenum ppm 85 732
Manganese ppm   4
Magnesium ppm 525 1162
Calcium ppm 4300 2381
Phosphorus ppm 1000 862
Zinc ppm 1100 991
Sulfur ppm 20200 7511
CONTAMINANTS
Silicon ppm >30 25
Sodium ppm >400 10
Potassium ppm >20 1
INFRA-RED
Soot % %   0.1
Nitration Abs/cm >20 21.6
Sulfation Abs/.1mm >30 55.9
FLUID DEGRADATION
Oxidation Abs/.1mm >25 48.1
Base Number (BN) mg KOH/g 11.0 7.78
VISUAL
White Metal scalar NONE NONE
Yellow Metal scalar NONE NONE
Precipitate scalar NONE NONE
Silt scalar NONE NONE
Debris scalar NONE NONE
Sand/Dirt scalar NONE NONE
Appearance scalar NORML NORML
Odor scalar NORML NORML
Emulsified Water scalar >0.2 NEG
Free Water scalar   NEG
FLUID PROPERTIES
Visc @ 100°C cSt 11.19 12.7
  • Thanks 1
The HPL is cleaning the heck outta that EB carbon maker. It’s real oxidation and the HPL is measuring a SAE 40 because of it.
Detectable soot = cleaning going on and or your tune efficiency not  optimum. I’d change out the oil filter and top up. Change plugs , air filter, and ask HPL to do a GC for fuel’s dilution. No way this is an accurate fuel’s dilution.
Thanks for sharing.
  • Thanks 1
    RyGuy43
    RyGuy43
  • Who's Online   3 Members, 1 Anonymous, 559 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
