Biggest Tire - 2IN RC Level
Hey,
I recently leveled my 2016 GMC Sierra 1500 All Terrain. The front even sits slightly higher than the rear from the ground.
I want the tallest tire I can run. I am okay with a little rub.
Looking at the 285/65R20 BFG KO2. I would like the Ridge Grapplers but heard they run larger in this size and it would rub.
Any suggestions/pictures of the same set up would be greatly appreciated.
That tire is almost a 35 I don't think it will fit in any brand. Depending on wheel offset 33 is about as big as you can go without rubbing.
Sent from my SM-G988U using Tapatalk
Go to the gallery, enter your stats. There are hundreds of trucks like yours with a 2" level. Run what they run.
www.customwheeloffset.com
I'm running a 305-55r20 Ridge Grappler on a leveling kit. Rubs rear fender liner with i think about 5.5" of backspacing. That tire is about 33.5". Not sure what a narrower tire would do.
