I just did mine install in 1 hour and 20 minutes, that includes running wires from the Switches, into the engine compartment for future use. Two things to help you do this install;
First, insert a long screwdriver into the hole in the rubber boot from the engine side into the cab. Do this for two reasons, one, made sure the path for the new wire is clear and unobstructed, second, while the screwdriver is installed, go into the cab and look were it is located, that way you have a idea were to look for the wire you are going to insert.
Second, spray a little wire lube in the rubber boot to make the wire slide in easier. Make up a 4 wire harness and stick it in the rubber boot after you insert the power wire. You might as well extend the wires from the switches while you have everything apart.
When my truck came in after waiting out the strike I noticed the upfitter switch kit on the back seat. When I asked the salesman about it he said that Was to be installed by the customer. I said well I have a check for $75,000.00 to pick up the truck but you won’t be getting it till the switches are installed. The next day I picked up the truck with the switches installed problem solved.
28 minutes ago, mostcorey95 said:
I was told by my dealer I cant install them due to not having the rpo code 9L7
I figured on something like that as well. I just wanted the hardware and fuses. If I have to, I'll wire them to battery power. I'm probably going to be running most of my accessories through a relay anyway. It'll pretty much be mostly lighting.
On 3/26/2020 at 4:17 PM, blamkin86 said:
First, grab the fuse box, and hold it near where we'll be installing it:
First, the black plug you just put on the red wire from the first steps, plug that into the fuse box. I don't have a picture of this, but there's only one place it can go.
At this point, you're switches are wired into the harness in your truck.
I understand you can change the 5 switches as to where they are used with ignition on / engine running and or engine off and hot at all times controlled by the switch. Someone said by moving the fuse over in the same slot but different connection within the slot. Anyone got the new fuse panel where they can take a photo of the open fuse access?
Chuck
So I  went on a quest to get more info on the famous knee bolster removal and replacement. I know the up fitters #153 has a small pictures to kinda get some info BUT not enough. It was discovered that half the dash must be removed to get to it! It is because of 1 screw under the radio trim. I found a GM link to a PDF file on how to remove the dash trims for replacement of various panels. Here is the link
https://photos.app.goo.gl/d2UVb4djaqf3ashL9
So now this shows where the screws are as well as the push clips.
I used the wrong link. Here is the correct link This is a PDF file.
https://www.gmupfitter.com/files/media/photo/1265/Instrument Panel Knee Bolster Replacement.pdf
Chuck
Edited by Gecko50
Thanks for the write up and the picks... For those of you not lucky enough to have GM at least change out the dash and gave you all the parts here are some photos to help with the process. FYI you have to disassemble a lot of things be prepared. I am also doing this on a 2020 AT4 3500.
1.  Push up on the gauge cover. Just the leather part.
5. Pull both sides away from center council
6. There are two tabs under the arm rest that need to be popped up then you can slide out the cup holder. Use =cation as there are wires attached. I disconnected one of them to be able to move it out of the way.
7. This is probably the worst piece of trim in the world to get off. Its the little piece just under the break controller. It has two wings that go down either side. There is a clip at the end of each wing one on the left side front and right side front and one in the center.
9. At the bottom you will see two screws to remove
10. Pull forward from the bottom to move the whole unit including the radio forward a couple of incest
11. Snaps around the edge will allow the radio to fall forward with the vents
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 252 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
