What kind of sd card do I need to purchase? I have a Silverado 1500 WT, so the USB ports are not for music. The 32 USB that I bought will not work for music. I would like to load music onto the SD card and put it into the navigation port. What should I buy, there are different types.
  • 3 months later...
On 4/23/2020 at 5:24 PM, Goobax said:
Come to find out, it’s just a matter of plug and play For those wanting to do this. No harness, no issues with flashing BCM. Super easy lol
The OEM Navigation Card is Plug and Play on the Elevation Preferred (IOS Infotainment)? Thanks
  • 3 months later...
So as of right now I just have the USB that came with my 2020 silverado trail boss custom.  I do not have nav.  I purchased the USB-C/USB-a/SD.  Will this just plug and play and work with my truck or do I have to have Nav for this part to function properly?
On 10/16/2020 at 9:16 PM, Duramax3oh said:
Well I know what I’ll be doing next, thanks! Now who wants to explain how to get songs and put on the SD card?? ?
My method is download music onto phone, plug phone into computer via USB, then copy file to SD card.  I but my music via Amazon.
You don't need nav to make this work, however I don't know if it's plug and play.  I have a Trail Boss LT.  It came with the USB card reader, but that trim doesn't even have nav as an option from the factory.
Thanks so much!  According to a YouTube video I found, and one other post on a different forum in here, it should be plug and play.  I just bought the component for $35.  Will post once I have it and it is all installed to let you guys know how it works out.
Edited by Zol15
Forgot to post the quote with it.
I didn't think a custom had a SD card slot.....thought on conv 2 pkg on LT trim or higher gives you SD
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
