@f0urtw3nty
I tore into it and got some measurements and pictures.
initial pipe is 2" x 2.75" oval at the very tip, about 1.3" in it goes to a perfect circle of 2.5" but also the pipe is angled downwards, so if you put a tip on it it will be pointing down unless you made some kind of pie cut and welded it on. But, if you follow the pipe back to where it goes flat, it looks somewhat level with the bumper cutouts. Only thing is that the hangers are in the way. The passenger side looks like you can cut it just before the hanger and possibly keep the passenger hanger, but the driver side is going to have to get removed and rewelded on. It's in a completely different location so that makes no sense.
I ended up ordering two exhaust tips at 2.5" inlet x 4" outlet x 18" in total length. That should be more then enough to span the gap with a little bit of tip poke like I wanted. They would get here around the first week of August.
I can only post one picture cause of the size, but you can see the S bend in it and the hanger location. That picture is of the passenger side
Edited by Yotaak
  • 3 weeks later...
Round tips have been installed in a rectangular hole, and i'm actually very happy with the outcome. I did have to make a exhaust hanger for the driver side exhaust, but besides that the install was fairly effortless. The tip size was  2.5" Inlet 4" Outlet 18" Long. I wish I ordered maybe a 2.75 inlet, because it was a STRUGGLE to get these to fit overtop of the stock exhaust. I figured the ID was 2.5" and the OD of the stock pipe was 2.5", so I figured it would slip on, I was wrong haha. It did change the sound quite a bit and im very happy with it.
I also debadged it while I was waiting for the tips to arrive. Very happy to get that massive z71 badge off my fender.
What do you guys think?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
