Guys...need some info please. I recently purchased a 2020 Silverado RST Z71. The dealer installed the 2.5 inch Trail Boss lift along with 35x12.5x22 tires. The wheels are OEM with a +28 offset. As you can imagine there is some rubbing. Initially I thought the rubbing was from the inner wheel well liners but it turns out to be the upper control arms. Now, I've contacted the dealer Service Manger and he thinks the fix would be adding a 1.5 to 2 inch level kit above the already 2.5 inch suspension lift that's on there. The truck sits with a rake so adding the level would fix that but will it fix the upper arm rubbing issue. Appreciate any info. This is the first truck that I've ever owned with anything higher than a level kit. Any info would be appreciated.
Those guys are trying to take your money. All you have to do is add a set of hub centric wheel spacers maybe 1/2” and you’re good. Adding more lift to the front end is not going to fix your tire rubbing on the UCA.
Edited by Ryguy
  • Sad 1
Couldn't agree more. A small wheel spacer will fix the rubbing on the UCA! Post more pics of the truck. Happy to see someone running 35s leveled.
Not sure how much it rubs but mine rubbed with 295s, I used a 1/4 inch spacer so the factory wheel studs were long enough without any problems. I don't think 1/2 inch will make it safely without longer studs. You should have atleast 5 at minimum full turns of threads with the nut.
I think this problem in your case is why you see guys running the 35 11.50s.
Edited by Flatblack83
Thanks guys. I do appreciate everyone's advice. I definitely looked into adding spacers however,  I decided to call the dealer and I told them to fix the rubbing issue at no cost to me. They installed the 2 inch level and it fully eliminated the rubbing issue on the UCA...I still have very minimal rub on the mud flaps but that's an easy fix. I guess 35x12.5s will work on stock 22" wheels with less than a 6inch lift. I feel much better now than a week ago..lol thanks guys...
On 5/3/2020 at 10:25 AM, Silverado4x4 said:
So now you have a 4.5 leveling kit? Man I would love to see pictures of the CV axle angles. I bet there not going to last long.
I would agree the CV axle angles are not ideal however, all work was performed by the Chevrolet dealer. Its something I'm going to watch very closely and if i start experiencing issues you can rest assured they will be making repairs at no cost to me...
eeek....thats a bit cringe worthy, or at least the angle of the photo makes it. Good call on the dealer install aspect.
Yeah I don't like that angle at all, worse when you go to full lock on the steering for the lower boot. The failure will be the boot at the front diff. how its pretty much fully extended at the top. But yes keep an eye out on them if they start slinging grease there done or if you feel or hear a popping noise when making a sharp turn.
I had this issue on my 2020 RST. I have a 3.5 inch rough country lift, with 33’s open country r/t. I went with a spacer for now. Im still wondering if getting a higher suspension lift would eliminate the inner tire from rubbing with the inner control arm?
So essentially they added a level kit to the OEM Trailboss 2" lift they installed originally?  Hopefully, the level kit they used is TB/AT4 specific which generally include UCAs...which kit did they use?
    ncleg
    ncleg
  • Who's Online   5 Members, 0 Anonymous, 755 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
