99-06 silverado extended brake lines
hello everyone was wondering if someone could help me out i have an 07' silverado 2wd lifted 6" and I'm looking for extended brake lines not sure how long I need however does anyone know a good length that'll work ? Thanks
I don't know if anyone makes pre-bent extended lines.  What I would do is to purchase the correct size(s) of NiCopp brake tubing, some fittings and rent a flaring tool and fabricate your own.  Working with NiCopp is really easy and it does not rust.
Good Luck!
I think the O.P. is referring to the flexible hoses going from the frame to the calipers (and the rear one going from the frame to the center of the rear axle).
Spoiler
Thanks.  I know less than nothing about lifted trucks.  Appreciate the insight!
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
