All,
My wife and kids are always looking for gift ideas for Fathers Day.  I realize there are a zillion options and it all depends on taste, but what are some good accessories under $100 that could be given as a gift?  I just got my truck last fall and pretty much only have Husky Liners and a Tonneau, so everything else is fair game.
Thanks in advance
Edited by vancealot29
Depending what package you have, you could convert some of your lights to LED's. I've got the LTZ, so I'll be converting my front turn signals and reverse lamps to LED lights. The brand is LasFit, and seem to have good reviews. Turn signals and reverse lamps are about ~$60. Obviously if you have the High Country then I believe you're already all set, ha.
Just food for thought.
Sent from my SM-G965U1 using Tapatalk
I have the LTZ too.  I've already done the license plate and reverse lights.  What light did you use for the front turn signals?
8 hours ago, RStrain56 said:
These are the ones I'm about to order...
https://www.amazon.com/dp/B08295BDG1/ref=cm_sw_r_other_apa_i_VpK2EbJAA56VE
So, not sure how accurate they are, but Amazon says this will not work in my truck.
When I look up what bulb to use for that on the pinned post, it shows Turn Signal/Marker - W21/5WLL, this bulb is a WY21W.  Is that the same thing?  Sorry for the ignorance, just double checking.
When I look up what bulb to use for that on the pinned post, it show Turn Signal/Marker - W21/5WLL, this bulb is a WY21W.  Is that the same thing?  Sorry for the ignorance, just double checking.
Nah, all good, sir. Amazon says the same thing for mine, but their(LasFit) YouTube video uses that model bulb and their website listed that same part number as well. You can double check their website for accuracy, but Amazon is for sure cheaper.
I’ve had the Lasfits in front for probably a year now. Great, durable lights. You get what you pay for.
Other inexpensive ideas...splash guards, bowtie puddle lamps, tailgate letter inlay, hitch cover, stubby antenna, black grill bowtie if you have a gold one, etc etc.
  • Like 3
Thanks for the help.
I found this one too, pretty sure its the same bulb you shared. Check out the text on the side of the box, "for off road use only". Tempted to try it for an extra $25 ???
https://www.amazon.com/Philips-W3x16d-CANbus-X-tremeUltinon-Indicator/dp/B07L8FD2YG/ref=mp_s_a_1_3?dchild=1&keywords=philips+wy21w&qid=1591393829&sprefix=philips+wy&sr=8-3
Thanks for the input.
I looked on the GM website and saw p/n's 84133640 and 84293092.  Besides price, what is the difference between these two? I could have overlooked it, but they look identical, except for the $30 price difference.
Thanks again.
Thanks again.
84293092 is the tiny little one for the corner of the grill on WT & Custom trims. Since you have an LTZ, you need the bigger, more expensive one (84133640).
Thanks. I filtered the results to only show items for my truck and it brought back both emblems. I will add this to the list.
Console organizer. The GM Accessories one is right around $50 if I'm remembering right.
Bed rail caps and console organizers. I just picked an organizer and the caps myself off Amazon.
Sent from my SM-N975U using Tapatalk
e8251d4321c55c7856ab25bcd8702eed.jpgb0d5e96d617b904fa6e0dc0f47c7c57f.jpg2343e01ecd9bc9831f8d653b50ad68ef.jpg
I added these to my list.  I haven't looked at the front yet, but I assume installation is similar to the rear?  2 screws and the assembly pops right out?  I don't really want to take off 2 or 3 other things to complete the task.....primarily cause I would probably break something in the process.
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
