In my experience, Rexing’s customer service has always been super slow. It has always taken me several days to a few weeks to get a response from them via email. When making a phone call, the hold time was always 30 min or more.
With regards to the white screen, I’d say it’s a software issue with your camera. Check the firm ware for the latest update. My camera, V1 with review camera, goes black after about 5-10 min of being on. Then once the key is turned off, it powers down within 2-3 minutes but will comeback on and record if the truck is rocked hard enough.
Yea they aren't doing phones right now because of COVID, so email is it.  In the beginning they responded somewhat quickly, but not anymore....even gmail was like 'its been a while since they responded, would you like to email again' hahaha
When powered on the display is always on for v3, you have to press the power button to toggle the display off and you hold it to shut the camera down.  I dont know if this is something you can change in settings though.  I want to hide it somewhat behind me rear view mirror so only the camera lens is visible and I'd like the screen to be off.
We'll see what they say...I just want to know what fuse size to use so I can close my fuse box up, been driving around with the cover off so I dont have to disassemble it again haha.
  • 5 weeks later...
UPDATE:
after pestering rexing more than a couple times and them giving me unrelated answers, and after returning mine and getting a new one because it was defective out of the box apparently, i got them to give me an answer on fusing:
Each wire on the permanent install harness, draws less than 1A.  The smallest fuse I could get in the ATR micro2 style is 5A, so i left the original size fuse in the existing fuse slot of the add-a-circuit, then installed a 5A fuse in each of the added circuit slots for each add-a-circuit.
Finally got my fuse boxed all closed up and everything works how I want, just waiting to have a friend help me get it mounted the way I want, using the suction cup mount for the mean time.
also i figured out, that I can make my display turn off after like 15s and make the beeping going away.
I plan on hiding mine in a similar area.
Just sharing this in case someone finds this thread while researching 2015.
I have a 2015 Silverado 1500 LT.
I'm adding a dashcam hardwire kit which allows for ACC and Constant power (for parking monitor)
Here's what I found in the left/driver's side fuse box:
- Fuses 2, 30, 31, and 32 appear to be ACC/switched
- The rest seem to be constant
- 9 was a spare, so I'm using that to tap for the constant
- 32 is heated steering wheel (which I don't have), so I'm tapping into that for ACC/Switched
- Line sides are highlighted with blue marker
Sorry for the crude labels.  Hope this helps someone.
For my dashcam install on my 2016, I too used those piggyback back add a tap double fuse holders. I used #36 which is a spare and hot all the time for constant power and then used #30 which is SEO ALC for switched power. SEO ALC stands for Special Equipment Option- Advanced Leveling Control which I don't have. So both of those were perfect options to use for me. I had been using #31 Accy/Run/Crnk for switched power and it worked just fine with no issues but was advised that it wasn't a good idea to tap that so I changed that to #30 instead.
Edited by mikeyk101
Mikey
I'm using #31 . So I should switch to #30?
5 hours ago, dieselfan1 said:
Mikey
Personally I don't think there is an issue with using #31. I had been doing that without any issue for a couple months and worked perfectly fine.  But in the previous thread where I detailed my connections, @benelliposted this:
"fuse #36 is fine for constant power,but i wouldnt use #31 for switched power. thats for run crank. You can use the large purple 50 amp APO RAP# 10. Thants switched power when key is on"
IMHO, that really didn't tell me why. The #31 fuse is actually Accy/Run/Crnk and not just run crank. Since it was simple enough to just switch over to #30, I went ahead and did it. Basically does the exact same thing that I got from #31 but wasn't sure if @benelli knew something I didn't and he never came back to that thread to elaborate further and explain his post. Using the #10 50 amp APO RAP fuse wasn't going to work for my situation.
Edited by mikeyk101
I don't need any issues so I'll switch it to 30 .
Thanks
On 6/17/2020 at 4:53 PM, DeathByNissan55 said:
I have a 2016 silverado.
Already have my rexing v3 dash cam installed, just haven't landed the wires because i'm not sure which fuses to replace with my harness.
My harness can be found here:
https://smile.amazon.com/gp/product/B07RN24B7V/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Here is the owners manual. go to page 406 for it to tell you which fuse box I'm running to and what each fuse is for (I'm running to the Left Instrument Cluster Fuse Block, left side of the dash, the door covers it when its closed):
http://www.american-automobile.com/2016_silverado.pdf
I really really REALLY hope I dont have to run it to the other fuse block instead since I already ran it over to the left one cleanly.
Right now my harness comes with 2x ATM style fuse taps, I know that this fuse box has micro fuses in it as well so I am prepared to cutt off the provided fuse taps to install the ones I have.
The picture in the amazon add describes that the yellow wire is for constant 12VDC power regardless of door being open/closed or ign being on/off, and red is for switching ignition power that only comes on when you have the key on.
I am getting zero support from the dealer, the mftr of the dashcam has provided me as much help as they can but they obviously dont want to take responsibility in case what they tell me affects another system which is understandable.
I reached out to a mobile car audio/electronics installer and they only seem to hardwire install things which I dont want to do.  The fuse taps take the place of the fuse is a much more reliable method as this dash cam draws almost no power, and its completely reversible in case I sell my vehicle.
Hope someone can help me out.
On a 2017 GMC it is #31 (ACC/Run Crk) for accessory and #26 (Spare-15A) for B+ constant power.
Folks, get a USB to generic adapter from Dongar technologies and plug the terminal ends into the connector that goes to your mirror.
On my GMT900s, that is pins 1 and 8.
simpleusbcable-12v-to-microusb-two-prong-universal-dashcam-adapter-813280_1024x1024.jpg?v=1651759097
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
