I installed mine on my 2020 Sierra 5.3 at about 1,500 miles. At 5,500 miles I decided to check it. So after 4,000 miles this is what I found; about half full which seemed to be 2 to 3 ounces.
That’s a fair amount of oil and it’s even more important to catch it on DI engines.
JLT
It's always nice to see results ! I just emptied mine as well and had quite a bit.
A catch can is considered a modification of the emissions system. Automatic voiding of your warranty the dealer tells me. Just a fyi.
Ive seen the same at 4000 miles
Thats crazy if true, a catch can is increasing reliability and over time reduce emissions as the valves will stay cleaner and seal better. Running premium gas won't even help a DI only engine, do these trucks use port as well as DI?
Sent from my SM-N975W using Tapatalk
DI only. You arent allowed to alter emissions components
It's easy to put the factory hose back and take the catch can out, there is no way they can prove you had one.
Of course as long as you remember to do it
On 7/4/2020 at 7:45 AM, chadman said:
JLT
On their site is a simple instruction paraphrased below.
Pull the hose between the PCV and the manifold. If there is no oil in it you don't need a can. If there is, you need one.
You don't need to ask a forum. You need to look for yourself.
This is awesome and you're right a must for DFI engines.  My previous truck was the 2016 2500HD with the 6.0L V8 but I think that engine was the last of the SFI.   DFI is nice, but it comes with a hiccup in gunk, these catch cans help eliminate that.
    • 3.19 @ Kroger’s in Montgomery Tx
    • We have now!  2027 GMC Sierra  Early look, but I'm a GMC guy and so far I think I like the looks of the Chevy better.
