Anyone Added Parking Sensors?
I have googled and looked through so many posts but have yet to find anyone who has actually had them added after purchase. Are dealerships able to add the sensors to an LT, and has anyone done it? What did it set you back?
I'm not positive, but I believe they cant add them. In addition to replacing the bumpers where they are located, they would have to be wired to hardware in the vehicle that you dont have on that model.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
