So I've been putting off taking my AT4 in for the recalls.Take it in yesterday finally. When I pick it up today, it's got a dent in the driver door right on the body line.
Dealer doesn't think PDR can take it out and talking about respraying whole door. No F'n way for a small dent.
Can PDR take this out.
Depends on the skills and experience of PDR guy.  Had a dent on my hood cap (no paint damage) PDR got it out. Completely gone and can't tell.  Is your paint damaged or just a dent?
PDR on a hard crease like that is very difficult.  I'm not sure they can do it where it will ever look right.  I'm sure you can call some and send a picture for an opinion.  Good luck.
Just now, davester said:
That looks like some paint is gone, so PDR would be out of the question....
No paint missing, just tiny scratch.
I would check different shops. My pdr guy has told me before that it’s super tough on body lines.
A good one can get that out, biggest problem they will run into is access to it. May have to pull inside door panel.
Hard to tell from the picture but it looks like its down to the primer/metal in which case you are $hit out of luck. Not sure what the big deal is about respraying the whole door. Any decent body shop has paint matching equipment to get it back to as good as factory.
FWIW of course the dealership is full of a bunch of goons. What did you expect? I never let them touch my vehicle. I had all 7 or so recalls done last month and that will be the first and last time my car ever goes back to the dealership barring an extremely important recall. Any competent mechanic has his own shop. Working at the dealership is like being a "union mechanic." Means that they suck at their job but they like the job security. Some dealerships are worse than others but you sure as hell aren't going to be getting the best and brightest at a Chevy dealership.
Edited by superhighsierra
I thought the same that's why I asked if there was paint damage. He said a small scratch.  Probably seeing a reflection. Even if paint is damaged,  I've fixed many scratches using Automotive touch up.com.  perfect match and used them for years on many colors. They're here in Louisiana. I use the base coat paint, layer the clear then wet sand until flat with the factory paint then buff. Comes out great. There's good tutorial vids on the site.
Edited by mafd2
So what are they going to do to remedy their fail?
That's a $1,000 loss in my book.
And give PDR a try.  Some of those guys are miracle workers.
Edited by steve841
lol, i seen the way they treat the cars in the back and I myself avoid the dealership like the plague as well.....recalls only time i bring it in there.....or warranty issue which never had one so far so......but yeah i am sure there are some good ones but its crapshoot at best.....
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 2,189 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
