120-Volt Outlet Question
My truck came with the 120-volt outlet in the bed.  Weird question, but does anyone know how long the battery would safely last if we were to plug in a small fan and run it with the truck not running?  My wife and kids want to go to a drive-in movie tonight but it's baking hot outside so they asked if we could run a fan.  I also have to leave the truck in the "On" position since you need to tune the radio to a certain frequency in order to get the sound for the movie.  I'm just wondering if doing these two things for a couple hours at the same time would run the battery down.
I would suggest getting a 12V fan or two instead, as the fan likely will just barely work (wattage-wise), and you avoid the inefficiency of converting 12V to 120V.
Pretty sure the truck has to running before that 120v outlet will power on.
Maximum power available is 400W, split between the 2 outlets.
At 120V, that's about  400/120 = 3,3 amps
