Is there an aftermarket computer I can put in my truck to give me more tuning ability? My 1990 OBD1 ECM is limited as to what I can do with it. It's an antique. Is there a later model ECM I can swap into this truck? I don't really want to go backwards and install an HEI and carburator but it's what I'm tempted to do. I've had this truck for 750,000 miles. I've been lucky so far to not be broke down and it's virtually been trouble free. The check engine light comes on and I start replacing parts then it goes off for another 30,000 miles or so. I just hate the fact I can't plug a laptop into it and see what's going on. (Yeah I know about Moates.com but that's a lot of hassle to still have limited tunability)
Where do you think you can improve it?true dual exhaust,e-fan, higher gear ratio are a few things you can do
Nope, nothing you plug in will do what you want.
I would go with a Holley Sniper system or similar. They are a fuel injection carb looking thing with sensors and a mini handheld computer that I believe you can also plug a laptop into.
Doesn't the ECM control other things like the a/c and shift points and convertor lockup?
Yeah.
I was just giving you an option. Standalone control systems is the only real way to get the adjustability you want. It would mean other things would have to be either gone away with or made function another way. Like a standalone transmission controller or making it manual valve body and figuring out the AC system.
It's either live with what you got or dive off the deep end with mods. Or just slap a 5.3/6.0 and have gobs more power/torque and fuel mileage compared to a TBI truck.
I've been doing OBD1 tuning since the late 90s.  Still do it today on my 89 and 94 Camaros.  You can get an OBD1 interface and the DataCat program from www.tunercat.com and be able to plug in and read all the codes you want.  DataCat is TunerCat's updated version of the old TTS Powersystems data logging programs and supports just about every one of the OBD1 truck ECMs from 88 to 95.  You can also buy the definition file and TunerCat tuning program to tune your truck as well, although you are also going to need some additional equipment such as EPROM burner, adapters, and EEPROM chips or an Ostrich to allow real time tuning.  Gets a little pricey if you want to do real tuning but no where near what it costs for OBD2 tuning.
There really is no sense in spending money on an expensive aftermarket ECM when the current one still works just fine.  However, unless you have done ECM/PCM tuning before, its not going to be something plug and play.  You are going to have to spend time and effort to learn what you are doing or risk damaging your engine and/or ECM.
Edited by LDM
Thanks. Yeah I've looked into it and seems to be a lot of stuff to get and a lot of stuff to learn. I think I'll just find someone to burn an Eprom for me. I just bought a zz4 Vortec engine so I need to eliminate the egr
If you are going with a ZZ4 I would probably just recommend the carb route.  You would need significant tuning to get a 90 ECM to work with a ZZ4 engine, they have much better heads and a far different cam/lift profile than the old stock TBI engine.  If you really do want to go EFI that has self tuning ability, the Holly Sniper EFI is suppose to be able to self tune without a laptop.  Not sure how well it works and its about $1400 so it is definitely a lot more costly than a carb.
  • 5 years later...
Do you still tune obd1?
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
