2 hours ago, Z71RAD88 said:
Have you noticed it catching water? Also, curious to know what your payload is on your AT4.
Its been out in the rain a few nights but didn't notice anything that I would consider excessive. First time I washed it before the tonneau the tailgate seem to collect some water, with it on washing no were near the same. Driving or parking during a rain nothing much like mentioned. My concern is the salt we get during the winter use, not being a daily driver should help and it also been to Ziebart already so that'll hold things off from deteriorating I'm sure.
14 hours ago, yousaveone said:
20500 on mine bought in 12-30-19
No issues just a couple recalls. Love the milage.
Curious what your recalls were? 20k huh? That’s probably the highest I’ve seen so far.
1 hour ago, yousaveone said:
Recalls  were 2 software updates and 1 DEF which so far seemed to help normalize def consumption
Were the software updates noticeable fixes for you or did you have your truck in for something else and the dealer just took care of the updates while it was in?
I think I had the same as 'yousaveone' did only one software update i think (remote start with the app that I never use) and the DEF recall/update. I had a check engine light on a few days, it went off literally on the way to the dealership. They cleared/updated and everything's been good since. I haven't noticed any difference good or bad
...glad to see I'm in good company of others who drive a lot. I bought mine with 8 miles on it back in March and now at 9,500. That's quite a bit of driving, but sounds like some of you are in the same boat. 70 mile round trip to work each day plus some short weekend trips.
The recalls were done just because I noticed it had them. With the exception of the DEF; one day the truck started using 5X more DEF a couple gallons every thousand miles. The DEF recall seems to have fixed it although some speculate that the DEF consumption is slowly calculated so the consumption issue may return.
Got it. It’s hard not to be excited about this engine with all that it offers. I feel it really checks all boxes for my needs as a family hauler for our long trips to visit family 3 hours away and being able to tow comfortably and safety a small travel trailer, of course with proper set up.
Just got back from a long towing trip and have 12,014 miles now!
2400 total mile trip, 2100 miles of that towing a 5.8-6.0k trailer. Sucked about 10 gallons of DEF during that timeframe.
Word of caution for those going on long drives, particularly towing. I’m going to start packing a 2.5 gal or 5.0 gal jug of DEF to have for safety PLUS a funnel!! Everything worked out fine for me but I noticed some places in the middle of nowhere don’t carry DEF, or it could be hard to find, or in this case one spot had some bottles of DEF but no funnels in the box or sold at the store. Always better to be prepared and not need it!
Yup, good recommendation.
15,000 on mine bought on 1/20/20. Love the truck. Love the mileage. Then two and a half weeks ago started to hear a sound of something under the cab/hood.  Looked under good and saw nothing out of the ordinary. Then check engine light came on. Took to dealer. They called and said that there was oil on engine. Wasn’t there before I took it there and must’ve happened on way. Been there two weeks dealer has been communicating w gm w no diagnosis. Then finally got a call from dealer yesterday saying they found the problem. Check engine light was O2 sensors but oil was from a blown seal. Replacing turbo, intercooler and other parts. Parts will be in Monday and truck should be done on weds. Will update when I get the work order When I pick it up. Even w problems still love engine and hasn’t soured my opinion yet. Sorry for hurried reply at kids party. Will update later.
Just went over 19K, zero complaints.Fuel filter life indicator  went below 35%, so I went ahead and replaced it.Easy job.
Is anyone out there using their 3.0 diesel to pull a gooseneck trailer? I intend to use it to pull a GN 3 horse trailer at 7500-8000 lbs. Does it hold level or will it need air bags or air shocks?
    • I have a hard time seeing oil from 'below' the rings 'pooling' in the cylinder. For an amount great enough to pool getting past the rings I would expect to see that same amount contributing to other noticeable symptoms, low compression, blow by, etc. You could try investigating for a stuck, gummed or carboned up ring, maybe an oil with different detergent strategy. Some other shade tree solutions like adding a detergent (or mystery oil) to the chamber and letting it sit, I've also heard of a heavy use of 'engine braking' to load the rings differently.   I would first be looking at oil entering from 'above' via a head issue, or intake/PCV issue. I suspect that the oil is entering cylinder 8 combustion chamber at all times but is getting burned off during each combustion event preventing a 'pool' from forming and lessening visible oil burning smoke. This leads back to valve stems or PCV system as the only route for oil to enter the chamber from. I would expect a PCV issue to not be isolated to cylinder 8 though.   Other considerations, how long does it take the pool to form? Could you look for the oil trail via the borescope? (Run the truck, shut the engine off, as quickly as practical, pull the plug and insert the scope and record to see how long and hopefully where from.)
    • National Average back up to $4.04 for gasoline and $5.35 for diesel.   https://gasprices.aaa.com
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
