Yesterday I ordered a 2021 3500HD and will be trading my 2019 Trail Boss LT. In the 1500, the Bose was available with the LT in convenience package 2. In the HD, it’s not available in the LT and requires LTZ. I don’t want the extra chrome goodies in the LTZ at a cost of about 5,000 more (I know there are other extras such as LED headlamps and ventilated seats but nothing I desire for the extra cost). I’m not interested in going to a full blown custom stereo install; but would like to add some upgrades to enhance the sound. Perhaps a subwoofer. Can anyone suggest some relatively mild upgrades which won’t require tearing into dash or excessive wiring modifications? Thanks in advance.
arent peeps adding that chevy accessory sub woofer or box that goes under rear seat....made by kicker i think....said it really helps the standard radio and am sure there are others out there as well......
but you can also have them install it and it would be complete when you receive the truck
Edited by Dunn
Thanks! I’ve looked at that and would consider it; just not sure if it fits since it’s marketed for the 1500. I assume the rear seat bolts which are used for mounting are in the same position for the 1500 and HD series trucks?
Requires work you don’t want to do but i upgraded (added) better front speakers in dash and new door speakers. Mine is is WT so basic model. Of course the stereo is so ridiculously basic that it doesn’t even have a balance or fader control which is totally assinine. But the speaker upgrade did add much needed sound
i had a 19 RST and now 20 2500 and interiors are identical...
EDIT: this is meant for trailboss1
Edited by Dunn
post above i did is meant for you.....i believe they are identical
The stock speakers in the non Bose system are terrible. The best bang for the buck is swapping those out. I added Infinity Reference to the doors and Kenwood Excelon to the dash, nothing fancy the whole set was under $300 on Crutchfield. I’ve also added the kicker sub and amp, it does make everything sound a bit better and add quite a bit at the low end. I don’t know if I’d buy the kicker kit if I installed the speakers before ordering. Start with speakers, then look at the kicker kit if you want to limit modifications to the truck.
  • 4 months later...
Thread from last year, but how hard are we talking to remove the door panels? I would just like to do a plug and play swap of the door speakers only but I'm not sure what all is involved.  I can really only find the new body 1500s on youtube. Are they the same doors as my 2021 2500 LT?  I guess I'm just nervous removing door panels on a 2 week old truck. But these stock speakers suck. Ha
Two 7mm screws on bottom of door. One behind door pull handle and two behind wood grain (or similar trim piece). Pry trim piece on the fat end first. 5 screws total. Once those are out start at front bottom corner and snatch the panel toward you. Plastic pins will pop right out. Two minute ordeal.
Awesome. Doesn't sound that bad and that sounds like what I saw on the 1500 video. Thanks!
Wow!!! $700 for that kicker kit!!
Anyone got good pics of what it looks like installed. Also where does it tie in to the factory harness for signal to power up and rca plugs for the sound. Or whatever it is they use. Google images weren’t that great.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
