Mine went in today for complimentary oil change and tire rotation. I have a little over 6k miles. I let them know about the noisy brakes and tech bulletin. Service adviser asked me if they do it hot or cold, I said mainly hot.  Mine get substantial worse after unhooking from my 24’ enclosed trailer. I will let you guys know what they do later today.
Got the truck back today.  New rotors installed after they discovered there was glazing/hard spots on them.  Took them a day or so to figure and get the higher powers of Gm warranty to approve.  Just picked up and quiet for now.  All under warranty
Well...spoke to soon as the brakes have started up again with the noise, though not as bad as 2 weeks ago.  Called dealer, stated they only replaced the front rotors and left all of the second round of pads on.  I brought truck into my garage and crawled under and the rear rotors have a shiny spot on the inner diameter of the rotors 3/4-1" wide.  Appointment again next week...
I had mine replaced via the TSB, good to go since. They were on backorder so took a few weeks but happy they honored and fixed it. Mine was built SEP19.
So got truck back a couple weeks ago, noise came back after front rotor replacement and new pads.  Brought back again, 3rd time, discovered that the front pads were installed backwards.  Driving for 3 weeks now and silent...
Just took mine in today for brakes squeaking and steering clunk noise. They also did a complimentary oil change and updated the software for a DEF issue?
Of course 9 hours later i get ahold of them and they tell me they could not replicate the brakes squeaking and humming and the steering column clunk... I told them i will be down there in the morning with my videos showing the noises... I even pointed out the service bulletin about the brake pads. 9 HOURS to do an oil change and software update and drive the truck around the block!!!!
Mine is in for the brake pad TSB right now. I had 17,000 miles on it and it was embarrassing to brake when I was driving slowly as they squealed like an old work truck.
I did have the troublesome pads and they are putting in the new ones.
They did get an “out of stock, back ordered” message from GM for the new pads but were able to get a set from another dealer in town.
So what does it sound like when you are having this issue?  I have been trying to track down a squek noise that I can't pinpoint when I'm driving but it is very annoying.  I've checked everything I know of which could be making the noise and it hasn't stopped?  You guys think this may be the issue?
What’s the difference in pads? Have a copy of the TSB? Mine squeal on in cold weather until they warm up (few times braking).
So dealer said the tech said my brakes and odds are perfectly fine. There’s some brake dust which is causing the squeaking and humming which is 100% normal.... wtf??? But wait if I want to resurface my brakes for $133 that’ll fix the squeaking.
Brake dust isn’t causing the squeaking of that was the case my camaro would never stop as the pads dust quite a bit
So just got home from picking up my truck... I gave them the TSB and they said i had the correct pads on. They kept telling me the squeaking and humming is normal and they can't do anything because 1. I'm over the 7500 miles to do the TSB and 2. I have the correct pads... The supervisor said he has a 2500 that does the same and he just lives with it..... i have never had a vehicle that does this and it be normal.... I even showed the service advisor my video and she said that is pretty loud.. UGH...
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
