I have a 2020 at4 with the duramax. My question is, how much def are others' trucks using? Mine seems to be pretty thirsty, much more so than previous diesels I've owned. I'm having to put a box of blue def in about every 600 miles. As soon as I put some in, it says something like '1000 miles of def remaining'. The display shows its full, but then it will drop to 250 remaining within a few hours.
How much towing does the truck see and how heavy is your foot? Both have a direct correlation to DEF volume from what I’ve experienced.
I would head up to the dealership ASAP.  Something isn't right.
I've got the 3.0L Duramax with 1300 miles on it now, and the DEF is still showing full.
If you are having to fill DEF that often, something is way out of spec.
we were towing an RPOD (about 3000lbs) for a few weeks... We noticed it was using a little more def, but now its way more. I am going to take it down to the dealer. We live about an hour from the dealer, so wanted to make sure this isn't normal before I make the trek down there.
3.0L on Z71 LT
Usage under normal conditions seems to be pretty light. Towing however it will gulp it up. Maybe 1000 miles I'll go through 4 gallons towing a 5800 lb travel trailer. So 1 box of DEF (at 2.5 gal) for 600 miles wouldn't seem to bad IF TOWING. With that said the DEF Gauge is terrible inaccurate during usage and when refilling.
You've got a problem then.  Is the check engine light on?
Edited by newdude
Agreed. Take it to the stealership.
I have hauled around town several weekends and still have not added any since I bought it. Sitting at 4,100 miles.
I'm curious as well.. I never tow anything and I'm at 1400 miles and my gauge hasn't moved.
DEF consumption should be 1 to 1.5 percent of the diesel burned. If the truck burns 100 gallons of diesel then it should not use more than 1.5 gallons of DEF. The computer relies on NOx sensors to determine how much DEF to add to the exhaust stream from the engine. If the sensor is failing or the programming is not done correctly then the DEF consumption can increase dramatically. I also found with my Duramax that the error codes were always incorrect which was the result of flawed controller programming by the kids at General Motors.
Out of 6 Chevy dealers I was only able to find one dealer with one mechanic who actually knew how to diagnose problems with the diesel DEF systems. My truck  was manufactured in 2011 and clearly GM has not improved their sensors and their programming since that time. I had the truck go into limp mode 4 times while more than 1000 miles from my house. I stopped using the truck for travel as it was not reliable.
I'm convinced there's still no diesel exhaust treatment system that actually works, and only gets worse in cold or heavy duty applications. Thats one reason ill never own a diesel that can't be deleted. When I bought my Ram I thought I'd leave it stock for 2 to 3 years and after a few months I had 2 codes so got rid of it then went 5 years with no issues.
My old man has a 16 LML and after a few years he started have so many issues he finally broke down and got it deleted and remembered how much he was missing (his last duramax was tuned from day 1)
Sent from my SM-N975W using Tapatalk
    • You need a better code reader/scanner.  You are missing codes.  Did the dealer give you a copy of the SAVI scan from that visit?     If the fluid hasn't been changed, change it.  Shudder will likely go away.
    • TLDR to my other post...   Hard. Pass.  Too many what ifs.     Are you set on a 3.0 Duramax?  Have you considered anything not GM just in case?  If you don't have to have a pickup, lots of other options for $27,000 out there.
    • I see some red flags.   - No mention in the Carfax if the oil pump belt was changed.  LM2s had a 150,000mi service interval, and its got 164,245mi on it.  So right out the gate it needs about $3000-3500 for that to be done before driving it another 150,000mi.  Belt is at the rear of the engine.     - If something happens to the transmission valve body, the special coverage is expired by mileage.  That will likely be an out of pocket expense, with zero or near zero GM participation if something happened even though its in by time.   - 2020 LM2s seem to need timing chains after 80,000mi at some point.  They fixed this end of 2020/starting 2021 model year engines.  They will usually set a P0016 I think?  There is another $8000-10,000 if it needs a chain.  The main chain is at the back, secondary at the front so the pump belt would be done at the same time if it needed chains.     - Long oil change intervals.  7,000-8,000mi on average, probably close to 0% or perhaps to or beyond 0% on the OLM.  Lots of them not at the dealer which makes me wonder how much of the oil ran through that truck was the proper Dexos D rated 0w20 oil and not just gas engine 0w20, which is not the same at all.     - Long fuel filter changes, again likely taking the fuel filter life to 0% or more.  First one went 28,603, second was done 43,094 miles later at 71,697, from there another 46,452mi to 118,149mi, and then the most recent one 37,026mi later at 155,175mi.  So counting its original fuel filter, its had only 4 fuel filters on it.  No bueno IMO.         Good news?    - It has had only two warranty trips to the dealer.  The first free service (end of December 2020 on the Carfax), and the transmission reprogram recall (end of August 2025 on the Carfax).     - Truck did a LOT of moving, so that might explain the lack of emissions related repairs like bad NOX sensors, bad exhaust temp sensors, bad glow plugs, etc.         The "emissions system checked" could just be how something was flagged for Carfax.  GM dealers have to do SAVI reports for warranty repair orders so they scan the truck.  So its possible that is there for that?
    • Thank you, @Z45!   NOTE - No all repair shop/Dealers reports to Carfax   That is my main concern.  The CARFAX looks way too clean for a 6 year old anything with 164,245 miles.  Even something known for reliability (like many Toyotas) typically has a lot more replaced, like a Nav screen, interior trim, shock/strut, or brake pads.  And surely the last set of tires (installed at ~58k miles) would be bald unless those were all highway miles.   I'm tempted to pay a local dealer to look up the VIN, but am not sure if that will be worthwhile.  Last time I did this, it was 100% useless, and I felt scammed - they noted the bumper was replaced years ago and that's it.  A 5-year old could spot the accident damage, even though nothing was on the CARFAX.   After giving the dealer a call, the truck may have a hard shift, but they have to verify with their mechanic if that's even a concern.  And I've test driven about a dozen of these now, many near Chicago, and half the trucks shift hard/odd at all throttle positions.  The ones with aftermarket lifts/larger tires shift terrible, and 3 stock trucks shifted so violently I thought the transmission valve body was going out.   At this point I'm conflicted, as I need a vehicle, and am coming up short locally.  Northern trucks in this price range tend to have either multiple owners, a lot of mods (lifts/oversized tires without re-gearing), and are generally in rougher shape.   If this truck showed up in your neighborhood for $27k and you had to purchase it sight-unseen, with the possibility of needing a 10L80 rebuild, torque converter, or rear end - would you do it?  I'm convinced most of the 10L80 trucks I test drove are broken, they can't all shift so bad, with massive flares/slipping/lurching and mis-matched downshifts like a teen driver learning stick.
    • From the spy shots, the front end does look like it's borrowing some styling cues from the Canyon. I'm more interested in the powertrain news than the screens though. If the 3.0 diesel survives into the next generation, that alone will keep a lot of current owners interested.
