My favorite at home is a local family owned. They serve all the favorites. My favorite from them is fried shrimp and a loaded bake potato. A few family Mexican and Chinese all good. Pizza and Italian a New York transplant. Of course barbecue is well represented. A monthly trip to Waco through Hearn TX a family restaurant that has the best catfish I’ve ever had. We limit ourselves to once a week out for our waistline. All the chains are represented around us. My wife’s a great cook, and enjoys cooking. But she gets that once a week break.
Sticker Shock
A new restaurant opened recently. Third in a local budding business. Most upscale of the three we are told. Staff says a personal designer we involved in the layout. Cruisin it's called. Car place. Hoods on the walls and diamond plate for the bar. Atmosphere galore. Food...not so much. Prices about par for the type. Way too much setting, not enough delivery and at a cost...whew....
We have just started going back to dine in, so my point of reference is not a fade but a sharp demarcation. Prices have literally doubled. My income did not. Quality is down a good quarter and service is, for the most part, unchanged. Most of the places we have gone have changed ownership but not staff. A few a total do-overs and some are just boarded up.
Guess I got spoiled to my own cooking and when I muff one at home it doesn't cost me a day's pay nor sit me on the pot for the next twelve hours. :crackup:Back to eating in more often.
Iowa Chop
The Porterhouse of Pork
On 5/22/2023 at 8:01 AM, Grumpy Bear said:
Pork Loin Bone In Chop
PBS Americas Test Kitchen had this method of pan frying a New York Strip that I tried on notoriously flavorless Yorkshire hog. You need a cut at least an inch thick for this and a good nonstick skillet.
Pat dry with a paper towel.
Salt liberally on both sides. (Nothing else but salt)
Wrap back in butcher paper and/or cellophane.
Refrigerate for 45 minutes but up to 24 hours. (I find overnight is best.)
Unwrap and pat dry both sides with a paper towel again. Salt will make it release some moisture.
Place the chop in a DRY, COLD skillet. NO OIL.
Place the skillet on the stove on medium HIGH for two minutes.
Flip the chop with tongs and turn heat down to medium. Another two minutes. Use a timer.
Turn every two minutes and start checking internal temperature at about 8 minutes or twice on each side.
If you like it a bit pink stop at 140 F. If you like it white 160F. Something in between? 😉 Two minutes per side.
(Use a rapid response thermometer)
Remove from skillet and let it rest on the cutting board tented in foil while you finish up your sides but at least 10 minutes.
Bone, season with flake salt and carve/serve.
Notes:
At the end of four minutes, you're going to think this looks awful. It will be notebook paper white. Keep going. I will build color as it caramelizes the fats. Tis the reason you need a slice at least an inch thick so it isn't dry as bone on the inside by the time it gets color or sheet white by the time the inside is at temp. If the cut is more than 2 inches (Iowa Chop) you will need to oven finish to get the internal temp without killing the outside. Inch to inch and a half is perfect.
If you have a glass top electric turn on the heat for about two minutes before you place the pan on it. I have one and they heat up more slowly than straight electric of gas.
This method cooks the meat evenly from both sides like baking and like baking adds zero extra fat but browns like frying. Zero splatter. Very moist, tender and guess what? Yorky has some flavor, who knew?
Try this as written before experimenting with other spices. Yorkshire does have some flavor after all. It just requires you to coax it out of the flesh.
If you cannot resist and are a pepper lover, wait to about the eight-minute mark to season with COARSE black pepper. It will burn if you do it to early or grind it to fine. Heat releases the peppers oils. Burnt is awful tasting.
If you're a garlic person. Rub the cooked pork with a roasted garlic clove when you put it on the board to rest and before the final salt seasoning. In the skillet it will burn even the oils. If you use raw garlic, it will taste like you're eating at Chili's.
I liked this so well I made the 100 mile plus trip to Kilgus Farms and bought a few packages of their Berkshire pork. And a shoulder roast. No need to waste a trip, right?
Hope ya all like this.
Same procedure as above but with an oven finish. 375 F for 10 minutes. At 2" thick it never gets to 140 in the center by the time the crust is fully formed. 10 minutes in the over gave a high 150 F center and a fully rendered fat band. Tasty stuff. I'll try 325 F nest time. I like a hint of pink.
I carved off a few slices and passed them to neighbors for their opinion. Got lots of smiles and a few questions about what I used as a rub to get such flavor. Salt and pepper :dunno:
Still haven't tried this with a Berkshire but I have two it the freezer waiting their turn.
Top Sirloin Butt
Coulotte Steak
Prep and cook as I have the pork chops, so I won't repeat here.
There are plenty of recipes for this cut with lots of herbs and seasoning but I wanted to know the meat first before playing with the flavor. I learned a few things.
Even thickness is really important, and beef responds to salt differently than pork in taste. This was good but almost over salted and one end over cooked. 140 F one end and 155 F the other. Not to ruination but medium well/well instead of medium. This cut is also half the price of a Strip Steak and 90% of the flavor.
Nice beefy flavor with a great texture and great mouth feel. Smells heavenly as the crust builds. I really liked this with salt and pepper only. 5-minute rest and juicy-juicy-juicy.
Tonight we had pulled pork sandwiches. I smoked this pork shoulder all day with mesquite.
Speaking of butt, I usually use butt but Aldi was sold out. Still came out great. Hard to make a better meal for less money.IMG_2607.thumb.jpeg.a606725bff542799658f296a7cfd7326.jpegIMG_2608.thumb.jpeg.f1a730ab1d9dac95bbf606493e9ce089.jpeg
  • Thanks 1
I LOVE mesquite. When I lived in El Paso I just went to the outskirts of town and harvested some. :)
17 minutes ago, OnTheReel said:
I stock mesquite and apple. Have no use for the rest!
No Hickory?
39 minutes ago, Grumpy Bear said:
No Hickory?
Not against it but honestly don’t think I’ve ever used it. Guess it kinda splits the difference between the strong mesquite and the mild fruit woods.
Ice!
Who would 'a thought? Our neighborhood has a community well. Rock hard water. 35 grain plus hard. We have a softener and an iron breaker, and the well manager treats with Clorine and whatever else the state requires.
My day ends with two fingers Kentucky Bourbon over a few cubes, and I had no idea how much the ice altered the taste of the drink until tonight. We had an RO unit added for drinking water and the ice maker in the fridge yesterday and so last night I emptied the cube dispenser and started anew. You can bypass the fridge filter to and save a hundred plus a year.
WOW! When you buy RO water from a treatment company, they add back some calcium and magnesium to 'flavor' the water. A point of use RO does not. This ice then is tasteless and pure. You would not believe how much taste ice imparts to your night cap. You would not believe how much minerals cloud water and what residue it leaves in the bottom of your glass. The ice is not crystal clear, but it is far clearer than non-RO waters. Perfectly clear ice has more to do with the way it freezes than what's in it. That's another topic.
Great source of water for your trucks cooling system too. 😉 Battery if you still do lead/acid. :dunno:
6 hours ago, Grumpy Bear said:
Ice!
I get my water through the refrigerator filtration. It gets the chlorine taste out. I still get white residue on my coffee pot. A friend of mine instead of using ice puts her whisky in the freezer. I don’t use ice, just a splash of water. Or nothing.
Reverse Osmosis takes it 'all' out. :) Going to make our first batch of Ice Tea from it today.
Did some jerky in it’s simplest form. Top round, sliced ~1/4”, seasoned with garlic salt and black pepper, cured overnight. Then smoked and dehydrated for around 6 hours. Haven’t touched the store bought jerky in years. It’s not even close.IMG_3425.thumb.jpeg.bc0e6f9d29a7e3a396791f5a9207e18b.jpeg
  • Thanks 1
  • 3 weeks later...
I'm kind of an Avocado junkie.
Recently I've had a good supply of perfectly ripe fruits. My neighbor grows a variety of pepper plants and has been supplying me with a few very nice Melrose Peppers. I took one and capped, cleaned, seeded and veined one then minced it into oblivion. The aroma as the oil released was wonderful. They are something like a green bell but without the bitterness and a hint of pepperiness. A little acid from lemon juice. Some EVOO and seasoning, salt and pepper and I had a nice new twist on this fruit. No basil. No garlic. A dusting of dried onion powder. L
I got an unusually nice store-bought commercial tomato somehow. More flavor than it should have had. Slice that up.
A shmear of the avocado on some sundried Roma artisan bread, no butter please, with tomato and a bit of the best Pastrami I've tasted in quite some time. Saw it in Imboden's deli counter slice so thin you could read a Gutenberg Bible through it. Easy though. It's salty enough to hide all that avocado wonderful.
The heck with a picture, GULP. :P
Did you know that soaking a thinning sliced red onion in ice water for thirty minutes takes that nasty acidic bite out of it? America's Test Kitchen tip.
Chuao Honeycomb Chocolate
This a 60% cocoa with honey caramelized to a crunch and blended with some honeycomb. 80 grams to a package. This is nice with a bourbon nightcap. They say it's two servings. I just had a square per evening. Lasted awhile. 95% fair trade. We picked up a package at our run to Mineral Point Wisconsin.
ChuaoChocolatier.com.
    • I'm suborn like that Ed. There's a plaque in my doctor office that says, "Don't quit, take a break." Works for allot of things.    Reality is, the wife loves her SUV and even given it's issues, she'd buy another if she found one with low enough miles. Then again she has me to maintain it.    Most of what ails this thing is GM shooting themselves in the foot and by extension the buyer. Besides a ridiculous breather system the cat warm up strategy, IMHO, is the dumbest thing I've ever seen an OEM do to a vehicle they warranty. On cold start it r-e-t-a-r-d-s the ignition to like -17* ATDC and dump fuel like kicking over a pail to force combustion in the CAT's for rapid warm up. This literally hoses the oil off cylinder walls and creates enough varnish precursors to stick rings in even well maintained engines. THEN if that wasn't bad enough they recommend using a wanting fluid specification at equally stupid interval.    Common to all GDI motors I'm aware of is this silly practice of driving the HPFP off the cam giving a leaking pump direct and unchecked access to the crankcase. And sir, eventually the ALL leak. Your job is to "catch it if you can". Yes, these are the same people that removed dipsticks from engines and transmissions in belief Joe Average wasn't capable of checking, reading and maintain his own vehicles fluids. Sadly  and in large they were correct. Most people these days can't tell a sparkplug from a fire plug.  Great ideas one and all.    Every move and every error calculated to defend themselves from the law and their own customers.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
