50 minutes ago, Grumpy Bear said:
A friend use to drive a diesel Rabbit. Use to get pretty close to 60mpg (open highway) if my memory is correct.
The Mazda 2 Coupe (Toyota iA in the USA) I owned for a short while before I traded it for Pepper was over 50 mpg...
CXS Freight claims they can move 1 ton of freight 500 miles on ONE gallon of diesel. (diesel/electric hybrid).
The technology is there.....the willingness to use it is weak.
There is no doubt that rail is a very important part of intermodal freight transport. As efficient as rail is, it pales in comparison to barges. However barge transport is pretty much limited to the Mississippi/Ohio and Columbia/Snake river systems. The rail companies have complained for years that they are at a competitive disadvantage to barges because of the federal subsidy provided by the Bureau of Reclamation and Army Corp of Engineers for construction and maintenance of dams and locks. They may have a point, however historically railroads have gotten huge federal subsidies of their own in the form of right-aways and large blocks of land in the west for simply building a rail line. Sorry for going way off topic.
That's why I said drive, but not own.
Kinda like renting a sports car once in awhile to relieve the itch.
I won't be owning a Hellcat or GT500 either.
Whenever I get the itch I test drive performance vehicles . One thing I noticed in the horsepower wars on public streets. There’s a horsepower threshold once reach your paying for bragging rights. Once all the driving and traction aids kick in your not feeling it. Not on the street. All wheel drive helps. Even the normal factory hot rods that are reasonable priced. 0-60 full horsepower use is a challenge. Even my mild tuned 14 GMC 5.3 on E-85 would flash the light merging on the freeway at times. My 92 blown truck had no problem breaking loose most anytime. I never thought I’d say it this high horsepower stuff is mostly wasted money.
Yes there is poly-ticks in everything. I was speaking only of the science and technology.
There is a red one about 25 miles from me. Not all the colors are that ugly. New battery is about $3K ish with install included. But they don't go bad often. I would consider a car like this on two conditions. 1.) It isn't UGLY and I think this one is cute. 2.) only for to and from and  around town. Even this one is a hybrid and would go much much further.
Beauty is in the eye of the beholder, brother, you’ve got some really UGLY taste. In Texas, a few years back, a truck wiped out the whole family. The whole vehicle (same vehicle) from back to front disintegrated, killing 4. Was an illegal alien! Want to save money, ride a bicycle and stay in your lane.
I can’t stand CRV’s and Hybrids especially when the cheap ass libtard wanting to save gas is driving ON THE FAST LANE!!!! Lol, I’LL NEVER BUY AN EV unless I can do far beyond 100mph
  • Haha 1
Tell me you your really feel.
:crackup:
Well, tomorrow, I’m going hog hunting, playing with new 308 rounds a buddy of mine hand loaded, so I’m really looking forward eradication of Antifa, oops, I meant hogs. That’s how I really feel, have a great night!
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
